PDF Page Bookmark issue 9 years 8 months ago #11139
  • apdeveloper
This is with regard to the bookmark functionality.
I am encountering an error on accessing the bookmarked page from the Bookmark tab. On clicking the Bookmark entry, it throws the following alert exception - 'Error Document, Can't Open'
Request you to kindly guide me on the same.
PDF Page Bookmark issue 9 years 8 months ago #11140
are you using the demo project?
can you share the pdf used to reproduce this issue?
PDF Page Bookmark issue 8 years 10 months ago #12646
  • manwon
  • manwon's Avatar
I found the issue how can trigger it. I quit the app after add bookmark and then rebuild the apps. It will show document cannot open.
But I add bookmark and quit app. I don't rebuild the apps. I click the app icon to open the app. The bookmark is work.
Last edit: by manwon.
PDF Page Bookmark issue 8 years 10 months ago #12650
Can you better explain?
"quit the app" and "rebuild the apps" are action that you do with Xcode? Or are you closing the app from device and then reopen it?
Can you reproduce this issue also with demo project?
PDF Page Bookmark issue 8 years 10 months ago #12651
  • manwon
  • manwon's Avatar
Sorry, my English is not good. I try to explain better.
Problem case:
First I install the app in Xcode and then add the bookmark. The bookmark is work. Then stop the Xcode and rebuild it in Xcode again. The bookmark will not work show the message Document cannot open.
Work case:
If I build the app in Xcode, also add the book mark. Then I also stop the Xcode. Only press the app icon. The bookmark is work
This issue also happen in demo project. I cannot reproduce it.
PDF Page Bookmark issue 8 years 10 months ago #12653
the demo bookmark implementation store a file with the bookmark info, and also the pdf path is stored in this file.
When you run the application on iOS simulator, the application path changes every time:
first run:
.../Library/Developer/CoreSimulator/Devices/19B59FBA-D11B-4400-99B2-17E38578ADB3/data/Containers/Data/Application/D41536FF-20F8-49D7-BA33-DB27658025C2/Documents/help.pdf
second run:
.../Library/Developer/CoreSimulator/Devices/19B59FBA-D11B-4400-99B2-17E38578ADB3/data/Containers/Data/Application/F5E4C498-927A-4AD2-AD4E-24DB16E6D76B/Documents/help.pdf
unfortunately in this case the pdf path is changed and the opening action returns an error message because is using the old pdf path.
