Text Annotations are not parsed 9 years 5 months ago #11801
  • valkuz1
  • valkuz1's Avatar Topic Author
Apart from editing the PDF document via viewer (which I do successfully!), I need to do the following:
Just open the pdf file and prefill some text into text fields. (Without viewer)
However, when I open the PDF like this:
[doc open:_pdfPath :@""];
int pages = [doc pageCount];
for(int index = 0; index < pages; index++){
PDFPage *page = [doc page:index];
[page objsStart];
int annots = [page annotCount];
for(int annot = 0; annot < annots; annot++){
PDFAnnot *annotation = [page annotAtIndex:annot]; //iterate over annots
// I will get only these, fieldType of which is 1 or 4, but not 2!
I get only annotations of type 1 and 4, but none of type 2.
But, when I open the pdf via pdf viewer, I am able to edit text fields (and also use annotAtIndex methods and etc to correctly get my text annotations)
So,
1)Why the text annotations are not parsed?
2)What should be done?
Text Annotations are not parsed 9 years 5 months ago #11804
can you share the document used to test the reader?
We will check it to better understand the issue
Text Annotations are not parsed 9 years 5 months ago #11805
  • valkuz1
Any document, various pdf versions - from 1.3 to 1.7, but for instance this, which is in the attachment.
Text Annotations are not parsed 9 years 5 months ago #11806
  • valkuz1
When I open it via viewer, I can edit and save fields as I normal, but when I just want to do it programatically (open doc and iterate over the annots in order to fill the document), I get only these of type 1 and 4 (checkmarks and sigs), but not type 2( text fields)
Last edit: by valkuz1.
Text Annotations are not parsed 9 years 5 months ago #11808
I tried to iterate over the annotations of your pdf with this code (almost equal to your):
PDFDoc *doc = [[PDFDoc alloc] init];
    [doc open:filePath :@""];
        [page objsStart];
            NSLog(@"Annot index: %i", [annotation getIndex]);
            NSLog(@"Annot edit type: %i", [annotation getEditType]);
            NSLog(@"Annot field type: %i", [annotation fieldType]);
            NSLog(@"Annot type: %i", [annotation type]);
            NSLog(@"Annot value: %@", [annotation getEditText]);
The annotation count is 62 and the log shows the edit fields correctly.
The annotation at index 0 is an edit text annot (type:20, field type:2); what is the result if you try to call [page annotAtIndex:0]?
Text Annotations are not parsed 9 years 5 months ago #11809
  • valkuz1
sec
