Highlight function 8 years 11 months ago #12732
  • manwon
  • manwon's Avatar Topic Author
-(void)HighLight :(id)sender
    //0HighLight
    [m_view vSelStart];//start to select
    [m_view vSelMarkup:annotUnderlineColor :0];
    [popupMenu1 dismiss];
    if(true)
        m_bSel = false;
//        [m_view vSelEnd];
I change some code in the highlight function. I only saw the text will be markup. But no any highlight color shown.
Highlight function 8 years 11 months ago #12733
you should comment also "m_bSel = false;"
Highlight function 8 years 11 months ago #12735
  • manwon
I just comment all m_bSel = false; But not work.
Highlight function 8 years 11 months ago #12736
  • manwon
I don't have professional license. So I can't use the highlight function?
Highlight function 8 years 11 months ago #12737
Yes, you should have professional license to use this kind of annotations.
You could use demo project infos to develop and test your project.
Here is the specs page, to check the features of each license: www.radaeepdf.com/ecommerce/technical-specification
Highlight function 8 years 11 months ago #12738
  • manwon
Hello
I want to set the bubble position after select the text.
It is because the bubble out of the screen when I select the right or left text.
below is the image
Last edit: by manwon.
