Get StartIndex and EndIndex of highlighted text 8 years 5 months ago #13433
  • joshnaAppcare
  • joshnaAppcare's Avatar Topic Author
Thanks for your reply
what will be the implementation of methods - (int)getStartIndex; and - (int)getEndIndex; in PDFVSel
Get StartIndex and EndIndex of highlighted text 8 years 5 months ago #13439
Regarding the methods getStartIndex and getEndIndex the implementation is what i said in the previous post.
Get StartIndex and EndIndex of highlighted text 8 years 5 months ago #13441
  • joshnaAppcare
yes but you told to implement in PDFVPage as below
If you want to get indexes you can add in PDFVPage class two methods:
- (int)GetSelStartIndex
return [m_sel getStartIndex];
- (int)GetSelEndIndex
return [m_sel getEndIndex];
but what should be the implementation in PDFVSel
Get StartIndex and EndIndex of highlighted text 8 years 5 months ago #13446
In PDFVPage class, you could add in PDFVSel implementation getStartIndex and getEndIndex methods:
    return m_index1;
- (int)getEndIndex
    return m_index2;
Get StartIndex and EndIndex of highlighted text 8 years 3 months ago #13719
  • joshnaAppcare
But i am using pdfPage not using PDFVPage so how can i use these methods?
Get StartIndex and EndIndex of highlighted text 8 years 3 months ago #13727
if you correctly implemented the code in previous posts, you will be able to get start and end index of the selection in OnSelTouchEnd method (PDFView class).
The current implementation get the selection's rect with [vpage GetSelRect], but you can use getStartIndex and getEndtIndex (explained in previous posts) to get indexes.
To get the PDFVPage instance of the selected text, you can use [m_view vGetPage:m_cur_page] as OnSelTouchEnd method already does.
If it could help. you can also edit the OnSelEnd delegate method and add start and end index of the selection, to retrieve these informations in RDPDFViewController.
You can add this code in OnSelTouchEnd implementation:
int start = [vpage GetSelStartIndex];
int end = [vpage GetSelEndIndex];
then edit OnSelEnd in this way:
- (void)OnSelEnd:(float)x1 :(float)y1 :(float)x2 :(float)y2 :(int)start :(int)end;
