error when toggling between portrait and landscape mode 8 years 3 weeks ago #13957
To keep on focus your text field I suggest you to check the filedType in OnAnnotClicked method in RDPDFViewController class:
if (annot.fieldType == 1)
        currX = x;
        currY = y;
And so in shouldAutorotateToInterfaceOrientation method:
if (![textFd.text isEqual: @""]){
        [m_view setEditBoxWithText:textFd.text];
        [self OnSingleTapped:currX :currY];
So you could simulate a tap in your textField.
error when toggling between portrait and landscape mode 8 years 3 weeks ago #13960
  • pooja
  • pooja's Avatar Topic Author
Hi, I tried these changes but it still doesn't work.
error when toggling between portrait and landscape mode 8 years 2 weeks ago #13965
on rotation event the page is re-rendered, so you lose the current annotation instance.
You can get the annotation index when you tap on it the first time (add [m_annot getIndex], in PDFView class when the annotation is tapped), then get the same annotation after the rotation using the index.
In PDFView class you can add a method to force the OnAnnotEditBox with something like:
m_annot = [page annotAtIndex:index];
[m_annot getRect:&m_annot_rect];
annotRect.origin.x = m_annot_rect.left / m_scale;
annotRect.origin.y = m_annot_rect.top / m_scale;
annotRect.size.width = (m_annot_rect.right - m_annot_rect.left)/m_scale;
annotRect.size.height = (m_annot_rect.bottom - m_annot_rect.top)/m_scale;
[m_delegate OnAnnotEditBox :annotRect : nuri :([m_annot getEditTextSize]/m_scale) * [m_view vGetScale]];
