DeHighLight / Remove HighLight 13 years 2 weeks ago #3124
  • teradam
  • teradam's Avatar
I have the same problem too.
I want to remove the highlight annotation when i tap it.
I think it is not working because of Page_getAnnotFromPoint( pdfPage, x, y ) might have a bug.
( when I use Page_getAnnot(index), it works well.)
- (void)OnSingleTapped:(float)x :(float)y
	struct PDFV_POS pos;
	[m_view vGetPos:&pos];
	PDFVPage *vPage = [m_view vGetPage:pos.pageno];
	PDF_PAGE pdfPage = vPage.GetPage;
	NSLog(@"pdfPage:%@", [NSValue valueWithBytes:&pdfPage objCType:@encode(PDF_PAGE)]);
	// !!!: I can get pointer like "0x7b4cba0".
	PDF_ANNOT annot = Page_getAnnotFromPoint( pdfPage, x, y );
	NSLog(@"annot:%@", [NSValue valueWithBytes:&annot objCType:@encode(PDF_ANNOT)];
 	// !!!: I cannot get pointer like "00000000"
 	Page_removeAnnot(pdfPage, annot);
        annot = NULL;
        [m_view vRenderPage:pos.pageno];
DeHighLight / Remove HighLight 13 years 2 weeks ago #3125
it's wrong, you should:
	PDF_ANNOT annot = Page_getAnnotFromPoint( pdfPage, pos.x, pos.y );
and you'd better check vpage or pdfPage object is null.
DeHighLight / Remove HighLight 13 years 2 weeks ago #3129
  • teradam
  • teradam's Avatar
Thanks!
I checked that vPage and pdfPage object is not null.
And I modified my code to match your suggestions, but it still doesn't work.
DeHighLight / Remove HighLight 13 years 2 weeks ago #3131
[m_view vGetPos:&pos, x, y];
DeHighLight / Remove HighLight 13 years 2 weeks ago #3133
  • teradam
  • teradam's Avatar
Thanks!
I implemented below and my code works well! :lol:
PDFView.h
-(void)vGetPos:(struct PDFV_POS *)pos x:(float)x y:(float)y;
PDFView.m
- (void)vGetPos:(struct PDFV_POS *)pos x:(float)x y:(float)y
    [m_view vGetPos:pos :x :y ];
RDPDFViewController.m
-(void)OnSingleTapped:(float)x :(float)y
    [m_view vGetPos:&pos x:x y:y];
	PDF_ANNOT annot = Page_getAnnotFromPoint(pdfPage, pos.x, pos.y);
	annot = NULL;
