Android PDF Viewer SDK 3.5 beta 8 11 years 1 month ago #9051
A new beta version 3.5beta8 has been published.
3.5beta8:
- using ASIMD to optimize ARM64(AArch64) lib.
- speed up jpx decoding on arm64 platform.
- NEW interface: Annotation.GetRemoteDest()
- FIX an issue : signature become invalid for some type of PDF.
- FIX a crashed issue for Ink, on 64 bits platform.(native method "create" shall return long, not int).
- FIX some UI minor issues for PDFBotBar and PDFTopBar (PDFLayoutView(RDPDFReader) demo)
- modify some other native codes for fields.
Android PDF Viewer SDK 3.5 beta 9 11 years 2 weeks ago #9234
A new beta version 3.5beta9 has been published.
3.5beta9:
- continue to speed up jpx decoding both for arm32 and arm64.
- NEW PDF outline dialog to "RDPDFReader".
- NEW setting Global.debug_mode set false to disable "AvialMem" debug string.
- NEW method: Page.Annotation.GetFieldFlag() to know "is required" or "no export" flag.
-NEW methods:
now Text Field annotation can use these methods:
Get/SetEditTextColor
Get/SetFillColor
Get/SetStrokeColor
Get/SetStrokeWidth
- FIX all crashed issues
- FIX an issue for linear gradient filling.
- FIX issue for mono image rendering on 64 bits platform.
- FIX issue for ANR when load library on some old devices.
- FIX render issue for text field. Now, it become same to Actobat for Windows.
- FIX issue from PDFBatchTest.zip
- FIX issue for text field color setting.
- modified java codes for Page.AddAnnotBitmap() failed.
- all JNI objects has finalize() method, it can auto free memory now.
- found an issue in Global.Init() about temp path.
Android PDF Viewer SDK 3.5 beta 10 11 years 2 weeks ago #9256
A new beta version 3.5beta10 has been published.
3.5beta10
- FIX issue for transparency bitmap annotation.
- FIX a rendering issue for an open PDF file.(lines too thin)
- FIX issue for Document.EncryptAs()
- FIX rendering issue with the STAMP button
- generated java-doc
- modified java-doc for Matrix class.
- modified some java codes for null reference check.
