Android PDF Viewer SDK 3.5.1 beta 11 years 1 week ago #9271
A new beta version has been published here
3.5.1beta2
- FIX loading bad PDF file: PDF file seek "startxref" to find cross reference table, In some case files has "startref" not "startxref"
- FIX issue for set colors for text field when text field has null text value.
- FIX an issue for PDF file saving.
- OPTIMIZED color blending codes.
- OPTIMIZED radial gradient filling.
- fixed an issue when using font delegate
3.5.1beta1:
- NEW feature: add Form object and add resources to Form.
- NEW class Document.DocForm
--DocForm.AddResImage
--DocForm.AddResFont
--DocForm.AddResGState
--DocForm.AddResForm
--DocForm.SetContent
- NEW method Document.NewForm()
- NEW method Page.AddResForm()
- NEW demo codes int module PDFReader: com.radaee.reader.PDFTesAct.test_form()
- java-doc updated.
Android PDF Viewer SDK 3.5.1 beta3 10 years 11 months ago #9439
3.5.1beta3
- FIX the issue for empty page(empty arabic text page).
- FIX owner password issue for Document.EncryptAs()
Android PDF Viewer SDK 3.5.1 beta4 10 years 11 months ago #9453
3.5.1beta4
- FIX issue for gradient page
Android PDF Viewer SDK 3.5.1 beta5 10 years 11 months ago #9485
3.5.1beta5
- FIX crashed issue
Android PDF Viewer SDK 3.5.1 beta5 10 years 11 months ago #9503
  • rômfer
  • rômfer's Avatar
Warning:com.radaee.view.PDFPageView: can't find referenced method 'float sqrt(float)' in library class android.util.FloatMath
Warning:com.radaee.view.PDFVPage: can't find referenced method 'float sqrt(float)' in library class android.util.FloatMath
Warning:com.radaee.view.PDFView: can't find referenced method 'float sqrt(float)' in library class android.util.FloatMath
I was trying to update to Android 6.0 SDK, and now the app doesn't build because of the errors above.
FloatMath was deprecate long ago, and now has been removed.
Please change from:
float x = FloatMath.sqrt(y);
to:
float x = (float)Math.sqrt(y);
Android PDF Viewer SDK 3.5.1 beta5 10 years 11 months ago #9504
We're cleaning up code to get M compliance.
Stato tuned.
