Android PDF Viewer SDK 3.6.1beta 10 years 8 months ago #9876
  • support's Avatar Topic Author
3.6.1beta1
-- NEW method: Annotation.SetEditFont(); to set font of editbox.
-- CHANGE now skip annotation that not allow interact, when user click on page.
-- FIX transparency rendering for Bitmap with 2 same indexed values.
-- Small changes on Java code
Last edit: by support.
Android PDF Viewer SDK 3.6.1beta 10 years 8 months ago #9895
A new beta version has been published here :
3.6.1beta2
- FIX rendering issue for Patriot-20151116.pdf
- FIX issue for ViewPager and sime risk.
- modified java codes for com.radaee.view
Android PDF Viewer SDK 3.6.1beta 10 years 7 months ago #9932
3.6.1beta3
- FIX for text space issue.
- FIX issue, for adding annotations on signed page.
- FIX MotionEvent issue with ViewPager.
- FIX text rendering issue
- FIX render to bitmap issue
Android PDF Viewer SDK 3.6.1beta 10 years 7 months ago #9938
3.6.1beta4
- FIX issue for truetype font.
Android PDF Viewer SDK 3.6.1beta 10 years 6 months ago #10032
3.6.1beta5
- NEW optimize all pages size calcute.
- NEW method Document.GetPagesMaxSize(); this implements from native side, and great enhanced page size calcute.
- NEW java codes changed.
- NEW method Document.OpenStreamWithoutLoadingPages()
- NEW using backing thread to load PDF file(PDFLayout only)
- FIX modified PagerView codes to optimized http link loading.
- FIX other codes adjustment.
- FIX link issue, using UTF8 encoding for PDF Extension level instead of ASCII.
- FIX popup window crashed for PDFReader and RDPDFReader Module.
- FIX issue for importing/exporintg rotated page.
Android PDF Viewer SDK 3.6.1beta 10 years 6 months ago #10056
3.6.1beta6
- NEW cover caching on RDPDFReader Module (boolean save_thumb_in_cache in Global.java)
- FIX ANR issue for PDFLayout using Grid View loading PDF.
