Memory Problems in device with Android 5.0.2 4 years 11 months ago #15605
  • jomart
  • jomart's Avatar Topic Author
This is happening when the user is paginating PDF files and after some of them the app is closing with an OOM.
Memory Problems in device with Android 5.0.2 4 years 11 months ago #15606
dear user:
have you invoke PDFLayoutView.Close() before activity closed?
codes of demo:
protected void onDestroy() {
RadaeePluginCallback.getInstance().willCloseReader();
final PDFViewController vctrl = m_controller;
final Document doc = m_doc;
final PDFLayoutView view = m_view;
final PDFAssetStream astr = m_asset_stream;
final PDFHttpStream hstr = m_http_stream;
m_controller = null;
m_doc = null;
m_view = null;
m_asset_stream = null;
m_http_stream = null;
if(view != null) view.PDFCloseOnUI();
new Thread(){
public void run() {
if (vctrl != null) vctrl.onDestroy();
if (view != null) view.PDFClose();
if (doc != null) doc.Close();
if (astr != null) astr.close();
if (hstr != null) hstr.close();
Global.RemoveTmp();
synchronized (PDFViewAct.this) { PDFViewAct.this.notify(); }
}.start();
synchronized (this)
try { wait(1500); }
catch(Exception ignored) { }
super.onDestroy();
RadaeePluginCallback.getInstance().didCloseReader();
Memory Problems in device with Android 5.0.2 4 years 11 months ago #15607
we just found an crashed issue relate CCITT decoding.
you can update libraries from:
www.radaeetz.com/20210827_1_android.libs.zip
Memory Problems in device with Android 5.0.2 4 years 11 months ago #15609
  • jomart
Hello, Support.
The above code is from the new SDK version? Because we can't find that code in SDK version 3.55.5, what means CCITT decoding?, this link www.radaeetz.com/20210827_1_android.libs.zip is the newest RadaeePDF SDK?.
Memory Problems in device with Android 5.0.2 4 years 11 months ago #15610
yes, please download 3.60.2
the libraries are same to link here.
do not forgot to replace codes for package "com.radaee.pdf"
CCITT decoding, mainly is 1 bit image.
