package created from sample is Crashing 12 years 8 hours ago #6323
  • Yeshveer
  • Yeshveer's Avatar Topic Author
Hi
I am trying to give a POC to one of my client for an Winrt application. And I am facing the following problem. I am able to create a package in release mode but it is crashing on our tablet Acer having processor core i3. And same is happening with the Debug package also.
Previously it was not allowing me to create the package in Debug mode some error was coming there now some how it has resolved.
Earlier I was also receiving the System Violation Exception when I was running the application in the VS2012 with professional edition. This later got resolved when I opened the project in VS2013.
My Main problem is the app is not getting crashed when run in either release or debug mode through the code. I am able to perform annotation on the pdf and save them. But when creating a package and running on tablet it is crashing both release and debug mode.
I tried to create package from other system but there I am not able to run the application. It is showing the following error.
What I can do to overcome this problem and provide a package for the client.
package created from sample is Crashing 11 years 11 months ago #6328
  • goldkyo
  • goldkyo's Avatar
  • Thank you received: 2
The most possible reason for that you can run the demo application on your desktop computer but not on your tablet is that the authority level of the account running on the tablet is too low to install the application. Please refer to the following:
stackoverflow.com/questions/12756246/the...e-target-application
Thank you.
package created from sample is Crashing 11 years 11 months ago #6330
  • Yeshveer
Hi Goldkyo,
The app package is able to install but it is crashing after making some annotation in a pdf. And sometime when I am trying to select the pdf. I am not able to run it completely.
It is crashing and I am not able find what is the reason for this.
package created from sample is Crashing 11 years 11 months ago #6331
it seems the PDF file opened, not closed.
it occoured by APP, and can't access it in second time?
package created from sample is Crashing 11 years 11 months ago #6334
  • Yeshveer
So is there any changes that I could do here in the Sample code so that I could deliver a Poc to the Client.
Please explain because I tried with the fresh installation of package by restarting my system. Still the crash issue is there with the other files kept at other location in system which I tried with.
So the above point I don't think is causing this.
package created from sample is Crashing 11 years 11 months ago #6335
  • Yeshveer
I am providing the link for packages that I have created both are crashing after performing annotation.
Sample Package
Can check the problem by installing them
The think you mentioned is not making sense since the sample is running well through the VS2013 able to annotate and save changes in the pdf. But in packages it is crashing.
Last edit: by kobiz.
