Application freezes after RDPDFLib initialization 11 years 11 months ago #6941
  • Einstein
  • Einstein's Avatar Topic Author
I've noticed that my whole application freezes after some time after initializing your PDF library. If the below initialization code isn't executed my application DOES NOT freeze. Here's the code I'm using to initialize your library:
// I'm using the demo licence I found in your sample at this moment..
bool b = RDPDFLib::pdf::PDFGlobal::ActiveLicense(2, "Radaee", "Radaeepdf@gmail.com", "NVFWCW-ESABJE-H3CRUZ-WAJQ9H-ZEC20W-2XZ21C");
auto installationPath = Windows::ApplicationModel::Package::Current->InstalledLocation->Path;
RDPDFLib::pdf::PDFGlobal::FontFileListStart();
RDPDFLib::pdf::PDFGlobal::FontFileListAdd(installationPath + "\\Fonts\\times.ttf");
RDPDFLib::pdf::PDFGlobal::FontFileListEnd();
bool abc = RDPDFLib::pdf::PDFGlobal::SetDefaultFont("", "Times New Roman", false);
bool def = RDPDFLib::pdf::PDFGlobal::SetDefaultFont("", "Times New Roman", true);
ActiveLicence and both SetDefaultFont calls return true. Is there a bug in your code or am I doing something wrong?
Cheers
Application freezes after RDPDFLib initialization 11 years 11 months ago #6942
  • Einstein
I did some more testing and found out that if I leave just this line:
The application still freezes. Do you have any triggers that freeze the application if the library is activated using a demo licence or is this a bug?
Cheers
Application freezes after RDPDFLib initialization 11 years 11 months ago #6944
where are you placed codes on?
Application freezes after RDPDFLib initialization 11 years 11 months ago #6945
  • Einstein
I'm using this code from C++/CX and it's placed in a static method inside some class. It get's called from C# App.xaml.cs. Does it matter where I put this ActiveLicence call?
Application freezes after RDPDFLib initialization 11 years 11 months ago #6947
no matter, just want to reappears.
we are using C#, does you mean on RT and not in WP8?
Application freezes after RDPDFLib initialization 11 years 11 months ago #6948
  • Einstein
I'm using Windows Phone 8.1.
