Double Tap - single tap event still fires? 13 years 5 days ago #3320
  • adpward
  • adpward's Avatar Topic Author
I seem to have a bit of an issue with OnPDFDoubleTapped and OnPDFSingleTapped.
If I single tap, only OnPDFSingleTapped is invoked.
If I double tap, OnPDFSingleTapped is invoked followed by OnPDFDoubleTapped.
When I double tap, I only want OnPDFDoubleTapped to be invoked - can you please advice a way around this?
Double Tap - single tap event still fires? 13 years 5 days ago #3321
yes, gesture always fire single tap first.
Double Tap - single tap event still fires? 13 years 5 days ago #3324
  • adpward
Ok edited my response with more detail.
It's obvious that I use return True / False to get rid of the single press event.
My issue is this : -
My customer wants to single press to show / hide the buttons such that more of the view is available. So I've added some code to facilitate this.
I have added an event to the interface - OnDocumentClicked and fire it via m_listener.OnDocumentClicked().
What test can I perform in the single press event to prevent it from calling this method, because a double press is following?
Last edit: by Peessewhogs.
Double Tap - single tap event still fires? 13 years 5 days ago #3334
  • adpward
I have fixed this by adding a handler to the PDFReader class.
I invoke the handler with a postDelayed, using a 100ms delay, upon the OnPDFSingleTapped event firing. When the OnPDFDoubleTapped event fires, if a handler exists, it stops it using removeCallbacks.
Job done, looks great and is nice and responsive.
Double Tap - single tap event still fires? 11 years 10 months ago #7291
  • Semenovich
  • Semenovich's Avatar
Can you tell me the exact max delay between two taps that invokes OnPDFDoubleTapped? I need it to set the correct delay for handler.postDelayed() method.
