How to highlight searchable string 12 years 9 months ago #4091
  • arcmobile.div
  • arcmobile.div's Avatar Topic Author
While search a string i am getting a list of position RECT array,page no . From that array if i am going that page that search string should be highlighted . Can you tell us how to implement above mention !!!
How to highlight searchable string 12 years 9 months ago #4094
You can implement it as follows:
- you can set a variable based on which highlight all search query in a page for example (boolean findAll)
- in vDraw check your variable:
if( m_finder.find_get_page() == cur )
    if(findAll)
         m_finder.find_draw_all(bcan, vpage, left, top);
    else
         m_finder.find_draw(bcan, vpage, left, top);
- then in PDFVFinder add find_draw_all that look like: (note not tested)
protected void find_draw_all(Canvas canvas, PDFVPage page, int scrollx, int scrolly) {
	m_page_find_index = 0;
	while(m_page_find_index < m_page_find_cnt) {
		find_draw(canvas, page, scrollx, scrolly);
		m_page_find_index++;
