Form-Filling Checkbox Display Problem 12 years 8 months ago #4477
  • asleepingdor
  • asleepingdor's Avatar Topic Author
I am trying the form-filling function using pdfviewer-sdk 2.9.4.
But When I try to check a checkbox, a '4' displays instead of a tick symbol.
I have searched the forum and found in SDK-2.9.3beta5 there is "ZapfsGEAR font" included in the demo project.
So, would like to know is the above font included and can be referenced?
Or can there be other ways to treat the checkbox? (e.g. using a "X" to replace the tick symbol)
Form-Filling Checkbox Display Problem 12 years 8 months ago #4479
This is a screenshot taken from pdfviewer-sdk 2.9.4
as you can see, it's using a checkmark not '4'..
Make sure that you have the following code in Global.Init:
sub = new File(fonts_path);
		if( !sub.exists() )
			try
				InputStream src = assets.open("rdf013");
    			FileOutputStream dst = new FileOutputStream( new File(fonts_path) );
   				while( (read = src.read( buf )) > 0 )
   					dst.write( buf, 0, read );
   				dst.close();
   				src.close();
   				dst = null;
   				src = null;
			catch(Exception e)
		sub = null;
Form-Filling Checkbox Display Problem 11 years 10 months ago #7309
  • Semenovich
  • Semenovich's Avatar
I had the same problem. The problem was solved when I move assets from the radaee library to my main project.
