case expressions must be constant expressions 12 years 6 months ago #4921
  • bsautere
  • bsautere's Avatar Topic Author
I have this error when using the radar source code, in PDFReaderAct and PDFReaderOldAct : case expressions must be constant expressions. Apparently as of ADT14 switch cases using R.id. ... should be replaced by if then else. Do you plan to fix this ?
Bernard
Last edit: by rhys.
case expressions must be constant expressions 12 years 6 months ago #4922
it changed, plz wait...
case expressions must be constant expressions 12 years 6 months ago #4944
A new version 2.9.7beta5 has been pubblished..
This contains a fix to switch case problem
