Problems updating existing annotations 12 years 4 months ago #4958
  • sparklellama
  • sparklellama's Avatar Topic Author
If you have a Page.Annotation object (here called mAnnotation) and you increase the stroke width as follows...
mAnnotation.SetStrokeWidth(largerStrokeWidth);
And then refresh the view like this…..
mPdfView.vRender(somePDFVPage);
The annotation updated with a new stroke with, but there are two problems.
  • The bounding box of the annotation is not expanded, so the new (larger) stroke width is displayed clipped at the edges.
  • The reference to the annotation in mAnnotation becomes invalid, as the Annotation itself appears to move to a new location in memory. You cannot perform subsequent operations on the annotation or reliably get a reference to the new version of it.
  • Are these bugs in the library, or do you think I might have missed something?
    Problems updating existing annotations 12 years 4 months ago #4960
    you can modify bounding by:
    Annotation.GetRect
    //then modify rect coordinate
    Annotation.SetRect
    annotation object are not valid after vRender invoked.
    you can record index of Annotation by a loop in Annotation object.
    Problems updating existing annotations 12 years 4 months ago #4961
    i'll modify some codes, for convenience.
    plz wait next version.
    in next version, you can invoke:
    Annotation.GetIndexInPage()
    and bounding box is auto increasing when you Invoke Annotation.SetStrokeWidth().
    Problems updating existing annotations 12 years 4 months ago #4967
    A new version 2.9.7beta7 has been pubblished..
    it has the following modifications:
    - NEW interface Annotation.GetIndexInPage()
    - bounding box auto increasing, when user invoke Annotation.SetStrokeWidth()
    Problems updating existing annotations 12 years 4 months ago #4982
    • sparklellama
    GetIndexInPage() verified as working. Thank you.
    Still working on second item.
    Last edit: by soumyaranjan.behera@ggktech.com.
    Problems updating existing annotations 12 years 4 months ago #4985
    • sparklellama
    Thanks for the update to the bounding box. It works but there is a problem. If the annotation has been moved, the bounding box returns to its original position, and the annotation becomes clipped. I have created an image with some screen shots to help show the problem. Do you think that the library can be updated to correct this issue?
    Thank you very much. Image can be found at the following URL.
    www.asdeqlabs.com/wp-content/uploads/2014/01/pdfissue.png
    The following user(s) said Thank You: shvmsngh91
