DoubleTap on Nexus10 not triggered 12 years 2 months ago #6299
  • apait
  • apait's Avatar Topic Author
hi,
i just wanted to tell you: on Nexus10 the event onDoubleTap in PDFView.PDFGestureListener is never triggered.
Tested on Nexus7 and Nexus5, there it worked.
com.radaee.view.PDFView.PDFGestureListener.onDoubleTapEvent(MotionEvent)
could you look at this for your next releases?
thx!
DoubleTap on Nexus10 not triggered 12 years 2 weeks ago #6602
  • apait
ok, our fault, please close.
if anybody happens to step into this 'issue':
under settings, accessibility, magnification gestures: if triple-tap-zoom is activated, double-tap-gestures are not detected with the gesture-listener.
