How to use VSetPos and GoToPage 12 years 1 month ago #6466
  • ppanda15
  • ppanda15's Avatar Topic Author
I really new on Android development, and this might be a stupid question. How to use VSetPos? I read in the document and tried to start the document to the specific page and specific position on that page. However, I tried using VSetPos but nothing happened.
Second, about GoToPage, where is the best place should I put it into my code to make the document starts and go to the specific page I want? (now I put it on OnDraw() and add flag to make it be called only one time).
Lastly, how to get the current page, or should I calculate by current position divided by page height?
Thank you in advance for answers. ;)
How to use VSetPos and GoToPage 12 years 1 month ago #6467
To go to certain position try:
m_reader.vSetScale(m_reader.vGetScale(), x, y);
To open the pdf on a certain page:
m_reader.PDFOpen(m_doc, false, this);
m_reader.PDFGotoPage(10);
to get the current page:
You can get it from OnPageChanged when you implement PDFReaderListener, or you can add a get method in PDFReader for the value of the variable m_pageno
The following user(s) said Thank You: thuc
How to use VSetPos and GoToPage 12 years 1 month ago #6472
  • ppanda15
Thank you for your reply, @nermeen. :)
Last edit: by thuc.
