How to get zoom state 12 years 2 weeks ago #6620
  • douglasmedia
  • douglasmedia's Avatar Topic Author
I wan't to do an specific action when the page is zoomed in. So I need something like a zoom listener. How can I achieve that?
Thanks for your help!
How to get zoom state 12 years 2 weeks ago #6627
You can customize PDFView and ovveride vOnZoomEnd() .. or vOnTimer(Object)
check
www.androidpdf.mobi/forum/Android-develo...eed-more-events#6212
How to get zoom state 12 years 1 week ago #6643
  • douglasmedia
Thanks for your reply. I tried it by overriding the vOnZoomEnd()-Method and it works quiet well. But what I want is to disable a ViewPager when the pdf is zoomed in and enable the ViewPager again when the pdf document is zoomed out. How can I get those zoom states?
How to get zoom state 12 years 1 week ago #6653
You can do this by calling m_view.vGetScale() and compare the value with m_view.vGetMinScale() and m_view.vGetMaxScale()
