Double tap on a view 12 years 6 days ago #6713
  • petr.sklenicka
I have a little issue with a double tapping in a view within PDF document. When I perform double tap on the view, the method OnPDFDoubleTapped is called, which is fine. But before calling OnPDFDoubleTapped method, OnPDFSingleTapped method is called first.
Could you give me any advice, please, how can I stop calling the method OnPDFSingleTapped, when I perform only double tap in the view?
Double tap on a view 12 years 5 days ago #6721
if you have a professional or a premium license you can try this solution:
Override the onSingleTapConfirmed method in PDFView class with
vSingleTap( e.getX(), e.getY() );
        	if( m_listener != null && m_status == STA_MOVING )
        		m_status = STA_NONE;
    			if( m_listener.OnPDFSingleTapped(e.getX(), e.getY()) )
    				return true;
    			else
    				return false;
    		else
    			return false;
and Override the onSingleTapUp method in PDFView class with
return true;
