Fit to height 12 years 4 days ago #6747
  • Oktogen
  • Oktogen's Avatar Topic Author
We are using the professional edition of your PDF library. Anyhow, we are facing following problem when displaying the page as landscape: the page is not visible completely and we have to scroll. What we want is, that the whole page is visible when displaying the page as landscape (we don’t want to scroll).
Is this basic feature available in your library?
We have already gone through all available forums but we haven’t found any solution for this problem.
Thank you in advance for your immediate attention to this issue.
Best regards
Fit to height 12 years 4 days ago #6748
this is the default behavior of the page in landscape mode (it fits the width).
Check this:
www.androidpdf.mobi/forum/Android-develo...screen?start=12#5023
Or try to change def_view parameter in default_config() method of Global class.
Fit to height 12 years 4 days ago #6749
  • Oktogen
Thank you very much.
This works for me: Global.def_view = 3;
