How to add click listener of URLs in PDF? 11 years 11 months ago #6929
  • meeaaoon
  • meeaaoon's Avatar Topic Author
I want to open URLs which are part of PDF files in web browser. So can I get callback when user clicks on URL in PDF? if yes then how can I do that?
Regards
How to add click listener of URLs in PDF? 11 years 11 months ago #6934
Last edit: by poudel.
How to add click listener of URLs in PDF? 11 years 11 months ago #6992
  • meeaaoon
Thanks for your reply but the onOpenURI(String) method doesn't called when I tap url in a pdf?
How to add click listener of URLs in PDF? 11 years 11 months ago #7024
yes the onOpenURI(String) method it's called!
If you are using the demo project you have to click the "Do Button" to open the link.
