Save annotations and insert them on next load 11 years 11 months ago #7005
  • Gracanin
  • Gracanin's Avatar Topic Author
I managed to save a rectangle annotation. I don't want to save the annotation to the PDF instead I want to save it to a database.
How can I load all annotations from database and insert them into the PDF after opening the PDF file?
1. Open PDF
2. Load annotations for PDF
3. Load thumbnails
for example,
I have a saved rectangle (x1, y1, x2, y2) on page 6. How do I tell the library to add the rectangle to page 6 if I'm currently at page 0 (front page)?
The following user(s) said Thank You: sultan
Save annotations and insert them on next load 11 years 11 months ago #7006
  • Gracanin
Also, can I save text highlights and notes externally as well?
Save annotations and insert them on next load 11 years 7 months ago #7948
  • marais
  • marais's Avatar
Have you had any resolve on this? Im also trying to load saved rectangle.
Save annotations and insert them on next load 11 years 7 months ago #7949
for rectangle annotation:
save: record pageno and rect in PDF coordinate to DB.
load: load rect then, convert to DIB coordinate.
for markup(highlight and others) annotation:
save: record pageno and 2 points(start and end) in PDF coordinate.
load: load 2 points then, convert to DIB coordinate.
Save annotations and insert them on next load 11 years 7 months ago #7967
  • marais
  • marais's Avatar
I already have the loaded coordinates from the db. Is there a method to generate this DIB coordinate object?
Also when I have this DIB coordinate is there a method available i can pass this into to draw this hihglight on the required page?
Regards
Save annotations and insert them on next load 11 years 7 months ago #7969
PDFVPage vpage = PDFView.vGetPage(pageno);
dibx = vpage.ToDIBX(pdfx);
diby = vpage.ToDIBY(pdfy);
viewx = vpage.GetVX(PDFView.vGetX()) + dibx;
viewy = vpage.GetVY(PDFView.vGetY()) + diby;
