PDFViewDual hardcoded page numbers inside PDFCell 11 years 11 months ago #7048
  • Rashaverak
  • Rashaverak's Avatar Topic Author
It seems that using PDFViewDual.vGotoPage(page) for
page = 0 or page = 1 will always show double page consist of page 1 and 2
but what if I have to have logic where I need the PDFViewDual show me page 2 and 3 ? Currently it doesnt seem to be possible, which is really surprising because if I need to show a magazine/news like view, those do not have double pages [1,2][2,3] but [1][2,3][4,5]. Imagine how stupid double page advertisement look using your solution, you have first page bundled to right side of previous double page and second page as left page of the following doublepage.
Would be really great if you could publish your View sources so that it is possible to alter the hardcoded behaviour instead of writing it from scratch which I will have to do probably now.
PDFViewDual hardcoded page numbers inside PDFCell 11 years 11 months ago #7049
look at this:
www.androidpdf.mobi/forum/Android-develo...r-visualization#6438
If you want View sources you should buy a premium or a professional license.
PDFViewDual hardcoded page numbers inside PDFCell 11 years 11 months ago #7050
there are method:
PDFViewDual.vSetLayoutPara()
to show pages as [1] [2,3] [4,5] like these codes:
boolean duals[] = new boolean[1];
duals[0] = false;
PDFViewDual.vSetLayoutPara( null, duals, false );
PDFViewDual hardcoded page numbers inside PDFCell 11 years 11 months ago #7051
  • Rashaverak
Thank you about the licence option pointing out and also the code, works great.
PDFViewDual hardcoded page numbers inside PDFCell 11 years 11 months ago #7053
  • admin
  • admin's Avatar
Thanks, it worked for me too.
I can't find it in documentation.. www.androidpdf.mobi/documentation/javado...fex/PDFViewDual.html here? But there is not any vSetLayoutParam
Last edit: by vishwakarmaspot.
PDFViewDual hardcoded page numbers inside PDFCell 11 years 10 months ago #7071
Sorry the javadoc is not updated, we will update it soon
But the method does exist in the SDK
