ThumbnailView Question 11 years 11 months ago #7054
  • Chanwoo Park
  • Chanwoo Park's Avatar Topic Author
1) I'm trying to resize thumbnails. Could you tell me which method should I call ?
public void thumbOpen( Document doc, PDFThumbListener listener )
m_thumb.vOpen(doc, 8, 0x40CCCCCC, this);
m_thumb.vSetThumbListener(listener);
m_thumb.vResize(2*getWidth(), 2*getHeight()); --> I've tried this, but didn't work.
2) Also, trying to find out how I can make a certain thumbnail view bigger when I touch that thumbnail view. (or double-tap)
For example, when I touch Page 3 Thumbnail, a pop-up view which is three times bigger than the original will show up while Page 1, 2, 4, 5, .. will remain the same.
ThumbnailView Question 11 years 11 months ago #7056
1) To resize thumbnails try this:
m_thumb.vResize(getWidth(), getHeight());
LayoutParams lp = getLayoutParams();
lp.height = lp.height * 2;
lp.width = lp.width * 2;
setLayoutParams(lp);
Or you can even change the size of thumbnails in reader.xml
2) You can implement it yourself, check onTouchEvent(MotionEvent) method in PDFThumbView class
Last edit: by poudel.
