Multiple Notes at same location 11 years 10 months ago #7081
  • bashirisonline
  • bashirisonline's Avatar Topic Author
When I try to add notes to a page, the note is added successfully, but the problem is that when I try to add another note at the same place then it overlaps the older note, and hence the older note cannot be tapped/viewed.
is there any resolution for this problem.
Please update ASAP.
Last edit: by e6412@drdrb.com.
Multiple Notes at same location 11 years 10 months ago #7082
This is the default behavior of the demo app..
You can change this behavior yourself based on your requirements, you can use GetAnnotFromPoint(float, float) to help you in your implementation
Multiple Notes at same location 11 years 10 months ago #7087
  • bashirisonline
This is not the default behavior of demo app only, library also behaves the same way. How can I change the implementation so that no new note can overlap an already existing note.
Multiple Notes at same location 11 years 10 months ago #7088
You can check if there is a nother annotation around this location using GetAnnotFromPoint(float, float) before adding a new one
