java.lang.UnsatisfiedLinkError: Native method not 11 years 10 months ago #7085
  • miguel.garcia
  • miguel.garcia's Avatar Topic Author
Hi
We are developing an application using your pdfFramework and after purchasing the premium license, we have changed the package name and we are getting this error:
java.lang.UnsatisfiedLinkError: Native method not found:
Is it necessary to keep com.radaee.pdf as pdfreader package name?
Thanks a lot
java.lang.UnsatisfiedLinkError: Native method not 11 years 10 months ago #7089
you cannot change the package structure of the SDK or the native calls will break..
You need only to change the package name in the manifest of your app...
The following user(s) said Thank You: willie
java.lang.UnsatisfiedLinkError: Native method not 11 years 10 months ago #7090
  • miguel.garcia
Thanks a lot
java.lang.UnsatisfiedLinkError: Native method not 11 years 10 months ago #7093
copy "libs", "assets" subdir to your project, and invoke Global.Init() when App start.
java.lang.UnsatisfiedLinkError: Native method not 11 years 10 months ago #7101
  • miguel.garcia
Hi, then what we have to do? either keep package name structure or copy assets folder?
Thanks a lot
