center page horizontal und vertical 11 years 10 months ago #7221
  • custompdf
  • custompdf's Avatar Topic Author
I'm using PDFViewHorz to display the pdf when in portrait view.
I need to fit the pdf to height and because the pdf view height is not the the full screen height I can't use PDFViewVert or so.
It's a single site pdf and i want the page to be centered horizontally.
I tried to set Global.def_view = 3, tried to set the m_view.vSetPos(pos, w/2, h/2); but nothing works.
the pdf is centered vertical but I need both. vertical and horizontal.
Whatever I tried the pdf page stays at the left screen border.
Any ideas?
Because of the project deadline I really would need a quick answer if anyone knows how to get this work!
Last edit: by Chaâbane.
center page horizontal und vertical 11 years 10 months ago #7226
set def_view = 3 in Global.default_config(), but not out of Global class.
or invoke PDFReader.PDFSetViewer(3), at runtime.
center page horizontal und vertical 11 years 10 months ago #7228
  • custompdf
I do!
public static void default_config() {
		selColor = 0x400000C0;// selection color
		fling_dis = 1.0f;// 0.5-2
		fling_speed = 0.1f;// 0.05 - 0.2
		def_view = 3;// 0,1,2,3,4,5,6 0:vertical 1:horizon 2:curl effect 3:single
						// 4:SingleEx 5:Reflow, 6:show 2 page as 1 page in land
						// scape mode
		render_mode = 1;// 0,1,2 0:draft 1:normal 2:best
		dark_mode = false;// dark mode
		zoomLevel = 3;
		need_time_span = true;
		setAnnotTransparency(Color.TRANSPARENT);
Still the same. Pdf page sticks on left corner
center page horizontal und vertical 11 years 10 months ago #7254
  • custompdf
So there is no other way?
center page horizontal und vertical 11 years 9 months ago #7518
  • cerv82
  • cerv82's Avatar
I'm getting the same incorrect behavior, I could make the Page get centered using the PDFViewVert, but the content is being cropped at the bottom.
Any update on this?
center page horizontal und vertical 11 years 8 months ago #7615
  • cerv82
  • cerv82's Avatar
I know that is kind of late but I just figured out how to center the page, I'm showing only a single page and it fits the page View height/width. I can share my code, just let me know.
