lstat './700' failed: Device or resource busy 11 years 9 months ago #7406
  • kovel
  • kovel's Avatar Topic Author
Hello
Cannot remove PDF's file directory when it closed. Could you explain why it so?
lstat './700' failed: Device or resource busy 11 years 9 months ago #7408
have you invoked Document.Close(); ?
and close all other objects.
lstat './700' failed: Device or resource busy 11 years 9 months ago #7409
  • kovel
Fixed. Forgot about PDFFileStream... Why you do not do it in Document.Close() internally? Are you expect that it should be reusable stream?
