Maximum open Documents? 150? 11 years 9 months ago #7465
  • apait
  • apait's Avatar Topic Author
this is rather time-sensitive...
Is there a leak or restriction in your library for opening a bigger amount of documents?
I tested it with pdfs and with images (loaded into an empty pdf).
Everytime it reaches 150 i've got the EMFILE-Exception "Too Many Files opened"
Example:
Load 200 bitmaps in 200 documents. crashes at 150.
final int TESTSIZE = 200;
for(int i = 0; i < TESTSIZE; i++) {
	doc.Create(tempPdf);
	doc.SetCache(cache);
	Page page = doc.NewPage(0, 200, 200);
	content.Create();
	//set alpha for both fill and stroke
	DocGState dgs = doc.NewGState();
	dgs.SetFillAlpha(0x80);//set alpha value to 0.5
	dgs.SetStrokeAlpha(0x80);//set alpha value to 0.5
	ResGState rgs = page.AddResGState(dgs);
	content.GSSet(rgs);
	//write a bitmap
	content.GSSave();
	dgs.SetFillAlpha(255);//set alpha value to 1
	dgs.SetStrokeAlpha(255);//set alpha value to 1
	content.GSSet(rgs);
	Bitmap bmp = Bitmap.createBitmap(300, 600, Config.ARGB_8888);//must be ARGB_8888
	Bitmap bit=BitmapFactory.decodeFile(directoryPlusThumbnail);
	bmp = bit;
	DocImage dimg = doc.NewImage(bmp, true);
	bmp.recycle();
	ResImage rimg = page.AddResImage(dimg);
	Matrix mat = new Matrix( 200, 200, 0, 0 );
	content.GSSetMatrix(mat);
	mat.Destroy();
	content.DrawImage(rimg);
	content.GSRestore();
	page.AddContent(content, true);
	content.Destroy();
	page.Close();
Maximum open Documents? 150? 11 years 9 months ago #7466
  • apait
i am using the last version of your library...
Maximum open Documents? 150? 11 years 9 months ago #7469
Do you close the doc object?
m_doc.Save();
m_doc.Close();
m_doc = null;
Maximum open Documents? 150? 11 years 9 months ago #7470
  • apait
well, i would close it, when leaving the activity, of course.
but i can't close it while displaying the documents.
Maximum open Documents? 150? 11 years 9 months ago #7471
in your test codes, you opened 200 documents and not close it.
Maximum open Documents? 150? 11 years 9 months ago #7472
  • apait
i know. why should i open a document and close it rightafter?
that makes no sense, then i would not be able to display it...
(like i said, i'm recyling all the documents in my ondestroy()... but thats not the point).
we've got a viewpager. for every view, we got a single pdfreadercontroller with a document. everything works fine until the underlying document-array exceeds 150 documents. --> to many files open-exception
my example should just show you, that maybe it has something to do with not-closed-sockets/streams in your library ... ?
i figure you're closing everything on document.close(), but at the same time: you can't call document.close before exiting the activity.
same goes using PDFFileStream ...
it's not possible to open more than 150 docs.
