Maximum open Documents? 150? 11 years 9 months ago #7473
Document.close not free all resources, if Document opened from PDFStream.
there is PDFFileStream.Close() need to invoke after Document.Close().
otherwise file occupied.
and there is another choice:
u can use PDFMemStream instead. int this way, document saved in byte array.
Maximum open Documents? 150? 11 years 9 months ago #7485
  • apait
  • apait's Avatar Topic Author
okay, i could try pdfmemstream for opening pdfs.
but what about my example-code and loading bitmaps into documents? how can i avoid the EMFILE-Exception there?
Maximum open Documents? 150? 11 years 3 months ago #8855
Sorry for late reply.
To avoid the issue try looking at this demo project
About file limit: remember you're handling low resource devices.
