How to use radaeepdf library 11 years 9 months ago #7532
  • asliyanage
I need to use radaeepdf library.So i added com.radaee.pdfex_view jar file to my project.Then i try to use come as mentioned in demo example.But it doesn't allowa me to improt com.radaee.pdf.Document.Do i need to add any other jar files?
How to use radaeepdf library 11 years 9 months ago #7538
For integration, you can use the demo project as a lib, or you can copy/paste the project's content inside your project..
In both cases, if you don't have the license yet, you need to give your project "com.radaee.reader" as package name. (Eclipse:Right click you project -> Android Tools -> Rename Application package)
this way you can test all the features (as the demo project is activated with the premium license)
How to use radaeepdf library 11 years 9 months ago #7545
  • asliyanage
I tried adding the demo project as a library.
Below is my main class.
package com.radaee.reader;
import com.radaee.pdf.Document;
import com.radaee.pdf.Global;
import com.radaee.pdf.Page.Annotation;
import com.radaee.reader.PDFReader.PDFReaderListener;
import com.radaee.util.PDFThumbView;
import com.radaee.view.PDFVPage;
import android.support.v7.app.ActionBarActivity;
import android.os.Bundle;
import android.view.LayoutInflater;
import android.view.Menu;
import android.view.MenuItem;
import android.widget.RelativeLayout;
public class MainActivity extends ActionBarActivity implements PDFReaderListener{
private RelativeLayout m_layout;
private PDFReader m_reader = null;
private PDFThumbView m_thumb = null;
private Document doc;
private Document m_doc = new Document();
public final static String PATH_SD_CARD = "/20141017/Prime/pdf_previews";
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
m_layout = (RelativeLayout) LayoutInflater.from(this).inflate(R.layout.reader, null);
m_reader = (PDFReader) m_layout.findViewById(R.id.view);
m_doc.SetCache( PATH_SD_CARD + "/1.dat" );
m_reader.PDFOpen(doc,false, this);
m_thumb = (PDFThumbView) m_layout.findViewById(R.id.thumbs);
protected void onDestroy()
//m_vFiles.close();
/*if( m_vFiles != null )
m_vFiles.close();
m_vFiles = null;
if( m_thumb != null )
m_thumb.thumbClose();
m_thumb = null;
if( m_reader != null )
m_reader.PDFClose();
if( m_doc != null )
m_doc.Close();
Global.RemoveTmp();
super.onDestroy();
public boolean onCreateOptionsMenu(Menu menu) {
// Inflate the menu; this adds items to the action bar if it is present.
getMenuInflater().inflate(R.menu.main, menu);
return true;
public boolean onOptionsItemSelected(MenuItem item) {
// Handle action bar item clicks here. The action bar will
// automatically handle clicks on the Home/Up button, so long
// as you specify a parent activity in AndroidManifest.xml.
int id = item.getItemId();
if (id == R.id.action_settings) {
return true;
return super.onOptionsItemSelected(item);
public void OnPageModified(int pageno) {
// TODO Auto-generated method stub
public void OnPageChanged(int pageno) {
public void OnAnnotClicked(PDFVPage vpage, Annotation annot) {
public void OnSelectEnd(String text) {
public void OnOpenURI(String uri) {
public void OnOpenJS(String js) {
public void OnOpenMovie(String path) {
public void OnOpenSound(int[] paras, String path) {
public void OnOpenAttachment(String path) {
public void OnOpen3D(String path) {
The i got below error.
10-27 17:11:02.652: E/AndroidRuntime(29011): FATAL EXCEPTION: main
10-27 17:11:02.652: E/AndroidRuntime(29011): Process: com.radaee.reader, PID: 29011
10-27 17:11:02.652: E/AndroidRuntime(29011): java.lang.UnsatisfiedLinkError: Native method not found: com.radaee.pdf.Document.setCache:(ILjava/lang/String;)Z
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at com.radaee.pdf.Document.setCache(Native Method)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at com.radaee.pdf.Document.SetCache(Document.java:387)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at com.radaee.reader.MainActivity.onCreate(MainActivity.java:33)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at android.app.Activity.performCreate(Activity.java:5600)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1093)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2504)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2599)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at android.app.ActivityThread.access$900(ActivityThread.java:174)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1321)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at android.os.Handler.dispatchMessage(Handler.java:102)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at android.os.Looper.loop(Looper.java:146)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at android.app.ActivityThread.main(ActivityThread.java:5748)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at java.lang.reflect.Method.invokeNative(Native Method)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at java.lang.reflect.Method.invoke(Method.java:515)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1291)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1107)
10-27 17:11:02.652: E/AndroidRuntime(29011): 	at dalvik.system.NativeStart.main(Native Method)
I think the problem is with SetCache method.Is there any other way to set path for pdf files?
Last edit: by Docrishav.
How to use radaeepdf library 11 years 9 months ago #7550
plz, copy "libs" subdir to your project and invoke Global.Init() when APP start.
How to use radaeepdf library 11 years 9 months ago #7552
  • asliyanage
I added toe init method to onCreate as below .Now it doesn't show any pdf file ,just blank screen.
import java.io.File;
import android.os.Environment;
public class MainActivity extends ActionBarActivity implements PDFReaderListener {
	//public final static String PATH_SD_CARD = "/20141017/Prime/pdf_previews";
	File sdDir = Environment.getExternalStorageDirectory();
		// setContentView(R.layout.activity_main);
		try {
			Global.Init(this);
			m_doc.SetCache(sdDir.toString() + "/1.dat");
			// m_doc.
			m_reader.PDFOpen(doc, false, this);
			setContentView(m_layout);
		} catch (Exception e) {
			e.printStackTrace();
	protected void onDestroy() {
		// m_vFiles.close();
		 * if( m_vFiles != null ) { m_vFiles.close(); m_vFiles = null; }
		if (m_thumb != null) {
			m_thumb = null;
		if (m_reader != null)
		if (m_doc != null)
			m_doc.Close();
		Global.RemoveTmp();
		super.onDestroy();
		return true;
			return true;
when i click on the screen it gives me below error.
10-27 18:53:18.182: E/InputEventReceiver(1486): Exception dispatching input event.
10-27 18:53:18.182: E/MessageQueue-JNI(1486): Exception in MessageQueue callback: handleReceiveCallback
10-27 18:53:18.212: E/MessageQueue-JNI(1486): java.lang.NullPointerException
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at com.radaee.reader.PDFReader.OnPDFSingleTapped(PDFReader.java:235)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at com.radaee.view.PDFView$PDFGestureListener.onSingleTapUp(PDFView.java:548)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.GestureDetector.onTouchEvent(GestureDetector.java:1457)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at com.radaee.view.PDFView.motionNormal(PDFView.java:605)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at com.radaee.view.PDFView.vTouchEvent(PDFView.java:712)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at com.radaee.reader.PDFReader.onTouchEvent(PDFReader.java:1225)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.View.dispatchTouchEvent(View.java:8281)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.ViewGroup.dispatchTransformedTouchEvent(ViewGroup.java:2477)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:2209)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at com.android.internal.policy.impl.PhoneWindow$DecorView.superDispatchTouchEvent(PhoneWindow.java:2332)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at com.android.internal.policy.impl.PhoneWindow.superDispatchTouchEvent(PhoneWindow.java:1616)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.app.Activity.dispatchTouchEvent(Activity.java:2665)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.support.v7.app.ActionBarActivityDelegateICS$WindowCallbackWrapper.dispatchTouchEvent(ActionBarActivityDelegateICS.java:268)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at com.android.internal.policy.impl.PhoneWindow$DecorView.dispatchTouchEvent(PhoneWindow.java:2280)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.View.dispatchPointerEvent(View.java:8489)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.ViewRootImpl$ViewPostImeInputStage.processPointerEvent(ViewRootImpl.java:4890)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.ViewRootImpl$ViewPostImeInputStage.onProcess(ViewRootImpl.java:4741)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.ViewRootImpl$InputStage.deliver(ViewRootImpl.java:4295)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.ViewRootImpl$InputStage.onDeliverToNext(ViewRootImpl.java:4349)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.ViewRootImpl$InputStage.forward(ViewRootImpl.java:4318)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.ViewRootImpl$AsyncInputStage.forward(ViewRootImpl.java:4429)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.ViewRootImpl$InputStage.apply(ViewRootImpl.java:4326)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.ViewRootImpl$AsyncInputStage.apply(ViewRootImpl.java:4486)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.ViewRootImpl.deliverInputEvent(ViewRootImpl.java:6705)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.ViewRootImpl.doProcessInputEvents(ViewRootImpl.java:6584)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.ViewRootImpl.enqueueInputEvent(ViewRootImpl.java:6555)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.ViewRootImpl.enqueueInputEvent(ViewRootImpl.java:6520)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.ViewRootImpl$WindowInputEventReceiver.onInputEvent(ViewRootImpl.java:6785)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.view.InputEventReceiver.dispatchInputEvent(InputEventReceiver.java:185)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.os.MessageQueue.nativePollOnce(Native Method)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.os.MessageQueue.next(MessageQueue.java:138)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.os.Looper.loop(Looper.java:131)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at android.app.ActivityThread.main(ActivityThread.java:5748)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at java.lang.reflect.Method.invokeNative(Native Method)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at java.lang.reflect.Method.invoke(Method.java:515)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1291)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1107)
10-27 18:53:18.212: E/MessageQueue-JNI(1486): 	at dalvik.system.NativeStart.main(Native Method)
10-27 18:53:18.212: D/AndroidRuntime(1486): Shutting down VM
10-27 18:53:18.212: W/dalvikvm(1486): threadid=1: thread exiting with uncaught exception (group=0x41de9da0)
10-27 18:53:18.222: E/AndroidRuntime(1486): FATAL EXCEPTION: main
10-27 18:53:18.222: E/AndroidRuntime(1486): Process: com.radaee.reader, PID: 1486
10-27 18:53:18.222: E/AndroidRuntime(1486): java.lang.NullPointerException
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at com.radaee.reader.PDFReader.OnPDFSingleTapped(PDFReader.java:235)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at com.radaee.view.PDFView$PDFGestureListener.onSingleTapUp(PDFView.java:548)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.GestureDetector.onTouchEvent(GestureDetector.java:1457)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at com.radaee.view.PDFView.motionNormal(PDFView.java:605)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at com.radaee.view.PDFView.vTouchEvent(PDFView.java:712)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at com.radaee.reader.PDFReader.onTouchEvent(PDFReader.java:1225)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.View.dispatchTouchEvent(View.java:8281)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.ViewGroup.dispatchTransformedTouchEvent(ViewGroup.java:2477)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:2209)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at com.android.internal.policy.impl.PhoneWindow$DecorView.superDispatchTouchEvent(PhoneWindow.java:2332)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at com.android.internal.policy.impl.PhoneWindow.superDispatchTouchEvent(PhoneWindow.java:1616)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.app.Activity.dispatchTouchEvent(Activity.java:2665)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.support.v7.app.ActionBarActivityDelegateICS$WindowCallbackWrapper.dispatchTouchEvent(ActionBarActivityDelegateICS.java:268)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at com.android.internal.policy.impl.PhoneWindow$DecorView.dispatchTouchEvent(PhoneWindow.java:2280)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.View.dispatchPointerEvent(View.java:8489)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.ViewRootImpl$ViewPostImeInputStage.processPointerEvent(ViewRootImpl.java:4890)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.ViewRootImpl$ViewPostImeInputStage.onProcess(ViewRootImpl.java:4741)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.ViewRootImpl$InputStage.deliver(ViewRootImpl.java:4295)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.ViewRootImpl$InputStage.onDeliverToNext(ViewRootImpl.java:4349)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.ViewRootImpl$InputStage.forward(ViewRootImpl.java:4318)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.ViewRootImpl$AsyncInputStage.forward(ViewRootImpl.java:4429)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.ViewRootImpl$InputStage.apply(ViewRootImpl.java:4326)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.ViewRootImpl$AsyncInputStage.apply(ViewRootImpl.java:4486)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.ViewRootImpl.deliverInputEvent(ViewRootImpl.java:6705)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.ViewRootImpl.doProcessInputEvents(ViewRootImpl.java:6584)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.ViewRootImpl.enqueueInputEvent(ViewRootImpl.java:6555)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.ViewRootImpl.enqueueInputEvent(ViewRootImpl.java:6520)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.ViewRootImpl$WindowInputEventReceiver.onInputEvent(ViewRootImpl.java:6785)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.view.InputEventReceiver.dispatchInputEvent(InputEventReceiver.java:185)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.os.MessageQueue.nativePollOnce(Native Method)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.os.MessageQueue.next(MessageQueue.java:138)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.os.Looper.loop(Looper.java:131)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at android.app.ActivityThread.main(ActivityThread.java:5748)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at java.lang.reflect.Method.invokeNative(Native Method)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at java.lang.reflect.Method.invoke(Method.java:515)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1291)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1107)
10-27 18:53:18.222: E/AndroidRuntime(1486): 	at dalvik.system.NativeStart.main(Native Method)
How to use radaeepdf library 11 years 9 months ago #7557
plz follow ReaderActivity and ReaderController sample.
