Adding Annotations Not Functioning 11 years 8 months ago #7613
  • abhishekjaju
  • abhishekjaju's Avatar Topic Author
When I am searching "Android" text in whole PDF I am not able to add annotations correctly.
It will only search for the first "Android" text on every page of the whole pdf.
I want to addURI to all "Android" Word in the complete PDF.
So please give example to seach all "Android" words in PDF and get cordinates of every particular "Android" text.
I used below code for achiving, but I am not getting desired result.
public void AddAnnonateURI() {
String str = "Android";
int pagesCount = m_doc.GetPageCount();
for (int i = 0; i < pagesCount; i++) {
Page currentPage = m_doc.GetPage(i);
currentPage.ObjsStart();
// Finder mFinder = new Finder();
Finder mFinder = currentPage.FindOpen(str, true, true);
if (mFinder != null) {
int finds = mFinder.GetCount();
int ichar = mFinder.GetFirstChar(0);
int ichar_end = ichar + str.trim().length() - 1;
float rect[] = new float[4];
float rect_end[] = new float[4];
currentPage.ObjsGetCharRect(ichar, rect);
currentPage.ObjsGetCharRect(ichar_end, rect_end);
// currentPage.AddAnnotMarkup(ichar, ichar_end, 0);
currentPage.AddAnnotURI(new float[] { rect[0], rect[1],
rect_end[2], rect_end[3] }, str);
for (int j = 0; j < finds; j++) {
// System.err.println("page" + (i + 1));
// int foundIndex = mFinder.GetFirstChar(j);
mFinder.Close();
currentPage.Close();
// m_reader.PDFSave();
Last edit: by Nygashi.
Adding Annotations Not Functioning 11 years 8 months ago #7619
mFinder.GetCount(); may return 0
in this case, no found results.
Adding Annotations Not Functioning 11 years 8 months ago #7621
  • abhishekjaju
I am getting count more than one but not ab;le get co-ordinates of all them.
Only getting co-ordinates of only first match found.
Adding Annotations Not Functioning 11 years 8 months ago #7622
to get all found results,
you need a loop:
int fcount = mFinder.GetCount();
for( int ifind = 0; ifind < fcount; ifind++ )
Adding Annotations Not Functioning 11 years 8 months ago #7630
  • abhishekjaju
Please see my code..
I have already added the for loop.
The problem is that it will search for the First variable and add uri to it.
Even my loop is for 5 times it will go on to the first word 5 times and add annotations to it.
Please tell me how can we get the Yuri status of a word.. so my loop will skip the word which have already been associated.
Or tell me some other way as the above way is adding ton the first word all the time.
Adding Annotations Not Functioning 11 years 8 months ago #7650
This means that inside the loop you are always reading the first entry, you need to read the current loop's entry..
and you need to move the part that calculates the coordinates and add the annotation inside the loop.
int ichar = mFinder.GetFirstChar(j);
