Annotations ID's, it's possible? 11 years 8 months ago #7744
  • cerv82
  • cerv82's Avatar Topic Author
Is there a way to get the Annotations using some kind of ID?, Currently you can look for the annotations using their index, and coords, which is kind of meaningless because you don't know the index of each annotation and if you get the Annotation using the coords, you don't which annotation is if there are two or more annotations of the same kind.
Annotations ID's, it's possible? 11 years 8 months ago #7746
need new interfaces, may be in furture.
Annotations ID's, it's possible? 11 years 8 months ago #7780
Please check the beta version 3.2beta .
It has new interfaces: Annotation.GetName, Annotation.SetName, Page.GetAnnotByName
The following user(s) said Thank You: CTT
