Default orientation and Define resolution 11 years 8 months ago #7759
  • abhishekjaju
  • abhishekjaju's Avatar Topic Author
I tried all the things in the forum but PDF is still in vertical mode if do this.
How to change the orientation on PDF to landscape or horizontal.
Where can I change the resolution and fix the same as I need to run this on one device only with 1024*768.
