URI and Remove Highlight Not Working Together 11 years 7 months ago #7913
  • abhishekjaju
  • abhishekjaju's Avatar Topic Author
If there is uri on the page one cannot remove highlight.
The remove highlight is unable to select the area.
I tried various options but there is no option to avoid the conflict.
Both methods are conflicting with each other.
Can you tell me any way out for the same.
URI and Remove Highlight Not Working Together 11 years 7 months ago #7936
Can you explain with more details your issue?
URI and Remove Highlight Not Working Together 11 years 7 months ago #7939
  • abhishekjaju
I have added dictionary to a PDF from my custom database. My user can also highlight the PDF. But when I am trying to remove previous highlight with Yuri(dictionary) on it I am unable to do it. And once I remove the uri from it or take a new pdf, remove highlight is working fine.
I think SDK is not able to find the higlight area after uri is assigned to PDF.
Is there any way I can remove it via code through and button remove highlight from current page of PDF.
URI and Remove Highlight Not Working Together 11 years 7 months ago #7980
