Ink annotation using ReaderController 11 years 7 months ago #8145
  • ChrisDon
  • ChrisDon's Avatar Topic Author
I've added version3.2 as a library project to my project and using com.example.pdfhttpdemo.MainActivity example I'm able to display a PDF.
Do you have documentation on how I can draw and save ink annotations to the pdf?
I can't find any examples / tutorials.
Ink annotation using ReaderController 11 years 7 months ago #8150
open from http link, shall in readonly mode.
content from server can't be modified.
Ink annotation using ReaderController 11 years 7 months ago #8156
  • ChrisDon
I should have made this clear in the OP, I'm reading the PDFs from file.
See code below
	/** Title of the PDF being displayed - for tracking */
	private String mTitle;
    private ReaderController m_vPDF = null;
    private Document m_doc = new Document();
    private PDFHttpStream m_stream = new PDFHttpStream();
	/** Key for retrieving the pdf URL from the intent */
	public static final String KEY_PDF_URL = "KEY_PDF_URL";
	protected void onCreate(Bundle savedInstanceState) {
		super.onCreate(savedInstanceState);
		Global.Init(this);
        final String url = getIntent().getExtras().getString(KEY_PDF_URL);
        if (url != null) {
            String path = ResourceDownloadManager.getFilePathForUrl(url);
            if (DebugHandler.LOG_ENABLED) {
                DebugHandler.log(this, "PATH:" + Config.getSDCardPath() + " " + path);
            m_vPDF = new ReaderController(this);
            m_doc.Close();
            //m_stream.open(url);
            //int ret = m_doc.OpenStream(m_stream, null);
            int ret = m_doc.Open(path, null);
            switch( ret )
                case -1://need input password
                    finish();
                    break;
                case -2://unknown encryption
                    finish();
                    break;
                case -3://damaged or invalid format
                    finish();
                    break;
                case -10://access denied or invalid file path
                    finish();
                    break;
                case 0://succeeded, and continue
                    break;
                default://unknown error
                    finish();
                    break;
            if( ret == 0 )
                m_vPDF.open(m_doc);
                setContentView( m_vPDF );
        } else {
            finish();
		mTitle = getIntent().getStringExtra(DETAIL_TO_SHOW);
		getSupportActionBar().hide();
When I open the PDF, I see no buttons to select ink colour or save any changes. How do I enable these?
Ink annotation using ReaderController 11 years 7 months ago #8157
You can find all the examples you need in the main demo project (not http demo project), check PDFReaderAct and PDFReader
