Android ndk crash: ReferenceTable overflow 11 years 6 months ago #8226
  • Hewie
  • Hewie's Avatar Topic Author
Hello!
I have a problem to use sdk for my project.
I implement a function to get pdf ducument node data use Path class
getNode() function, when I call the function, I got logcat message below(Screenshot)
than my program were crush. It's any solutions to solve this problem?
This is my project informations
Android SDK: 4.4
Device: Asus Nexus7
PDF SDK Version: 2.9.3
Code:
public void TestPath() {
Path path = new Path();
path.MoveTo(0, 0);
int x = 0, y = 0;
Random random = new Random();
for(int i = 0; i < 1025; i++) {
x = random.nextInt(100);
y = random.nextInt(100);
System.out.println("x = " + y + " , " + "y = " + y);
path.LineTo(x, y);
path.CurveTo(100, 0, 100, 100, 30, 70);
path.ClosePath();
int cnt = path.GetNodeCount();
int cur = 0;
float point[] = new float[2];
while( cur < cnt )
path.GetNode(cur, point); // Error
cur++;
Page page = m_doc.GetPage(0);
page.ObjsStart();
Matrix mat = new Matrix( 1, 0, 0, -1, 0, m_doc.GetPageHeight(0) );
page.AddAnnotGlyph(mat, path, 0xFF0000, true);
page.Close();
path.Destroy();
Logcat:
12-29 22:56:34.459: W/dalvikvm(31424): JNI: pin count on array 0x432b4bc0 ([F) is now 61
12-29 22:56:34.459: I/System.out(31424): Path: 473 : 60 => 1
12-29 22:56:34.459: I/System.out(31424): 503.26538
12-29 22:56:34.459: I/System.out(31424): 625.3756
12-29 22:56:34.459: W/dalvikvm(31424): JNI: pin count on array 0x432b4bc0 ([F) is now 62
12-29 22:56:34.459: I/System.out(31424): Path: 473 : 61 => 1
12-29 22:56:34.459: I/System.out(31424): 485.00024
12-29 22:56:34.459: I/System.out(31424): 607.18317
12-29 22:56:34.459: W/dalvikvm(31424): JNI: pin count on array 0x432b4bc0 ([F) is now 63
12-29 22:56:34.459: I/System.out(31424): Path: 473 : 62 => 1
12-29 22:56:34.459: I/System.out(31424): 468.0114
12-29 22:56:34.459: I/System.out(31424): 591.6051
12-29 22:56:34.459: W/dalvikvm(31424): JNI: pin count on array 0x432b4bc0 ([F) is now 64
12-29 22:56:34.459: I/System.out(31424): Path: 473 : 63 => 1
12-29 22:56:34.459: I/System.out(31424): 456.5977
12-29 22:56:34.459: I/System.out(31424): 583.4371
12-29 22:56:34.459: W/dalvikvm(31424): JNI: pin count on array 0x432b4bc0 ([F) is now 65
12-29 22:56:34.459: I/System.out(31424): Path: 473 : 64 => 1
12-29 22:56:34.459: I/System.out(31424): 449.6581
12-29 22:56:34.459: I/System.out(31424): 584.03564
12-29 22:56:34.459: W/dalvikvm(31424): ReferenceTable overflow (max=1024)
12-29 22:56:34.459: W/dalvikvm(31424): JNI pinned array reference table (0x792bdac8) dump:
12-29 22:56:34.459: W/dalvikvm(31424): Last 10 entries (of 1024):
12-29 22:56:34.459: W/dalvikvm(31424): 1023: 0x432b4bc0 float[] (2 elements)
12-29 22:56:34.459: W/dalvikvm(31424): 1022: 0x432b4bc0 float[] (2 elements)
12-29 22:56:34.459: W/dalvikvm(31424): 1021: 0x432b4bc0 float[] (2 elements)
12-29 22:56:34.459: W/dalvikvm(31424): 1020: 0x432b4bc0 float[] (2 elements)
12-29 22:56:34.459: W/dalvikvm(31424): 1019: 0x432b4bc0 float[] (2 elements)
12-29 22:56:34.459: W/dalvikvm(31424): 1018: 0x432b4bc0 float[] (2 elements)
12-29 22:56:34.459: W/dalvikvm(31424): 1017: 0x432b4bc0 float[] (2 elements)
12-29 22:56:34.459: W/dalvikvm(31424): 1016: 0x432b4bc0 float[] (2 elements)
12-29 22:56:34.459: W/dalvikvm(31424): 1015: 0x432b4bc0 float[] (2 elements)
12-29 22:56:34.459: W/dalvikvm(31424): 1014: 0x432b4bc0 float[] (2 elements)
12-29 22:56:34.459: W/dalvikvm(31424): Summary:
12-29 22:56:34.459: W/dalvikvm(31424): 1 of byte[] (8192 elements)
12-29 22:56:34.459: W/dalvikvm(31424): 1023 of float[] (2 elements) (4 unique instances)
12-29 22:56:34.459: E/dalvikvm(31424): Failed adding to JNI pinned array ref table (1024 entries)
12-29 22:56:34.459: I/dalvikvm(31424): "main" prio=5 tid=1 RUNNABLE
12-29 22:56:34.459: I/dalvikvm(31424): | group="main" sCount=0 dsCount=0 obj=0x415d0ca8 self=0x414a4418
12-29 22:56:34.459: I/dalvikvm(31424): | sysTid=31424 nice=0 sched=0/0 cgrp=apps handle=1074020692
12-29 22:56:34.459: I/dalvikvm(31424): | state=R schedstat=( 0 0 0 ) utm=864 stm=185 core=1
12-29 22:56:34.459: I/dalvikvm(31424): at com.radaee.pdf.Path.getNode(Native Method)
12-29 22:56:34.459: I/dalvikvm(31424): at com.radaee.pdf.Path.GetNode(Path.java:93)
12-29 22:56:34.459: I/dalvikvm(31424): at com.radaee.reader.PDFReader.AnnotToDrawing(PDFReader.java:1996)
12-29 22:56:34.459: I/dalvikvm(31424): at com.radaee.reader.PDFReader.OutPutMarkUpModel(PDFReader.java:1936)
12-29 22:56:34.459: I/dalvikvm(31424): at cc.nexdoor.standalonepdfreader.PDFReaderActivity$3.onConfirmClick(PDFReaderActivity.java:444)
12-29 22:56:34.459: I/dalvikvm(31424): at cc.nexdoor.ent.cloudconference.ly.utils.DialogUtils$4.onClick(DialogUtils.java:147)
12-29 22:56:34.459: I/dalvikvm(31424): at android.view.View.performClick(View.java:4438)
12-29 22:56:34.459: I/dalvikvm(31424): at android.view.View$PerformClick.run(View.java:18422)
12-29 22:56:34.459: I/dalvikvm(31424): at android.os.Handler.handleCallback(Handler.java:733)
12-29 22:56:34.459: I/dalvikvm(31424): at android.os.Handler.dispatchMessage(Handler.java:95)
12-29 22:56:34.459: I/dalvikvm(31424): at android.os.Looper.loop(Looper.java:136)
12-29 22:56:34.459: I/dalvikvm(31424): at android.app.ActivityThread.main(ActivityThread.java:5001)
12-29 22:56:34.459: I/dalvikvm(31424): at java.lang.reflect.Method.invokeNative(Native Method)
12-29 22:56:34.459: I/dalvikvm(31424): at java.lang.reflect.Method.invoke(Method.java:515)
12-29 22:56:34.459: I/dalvikvm(31424): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:785)
12-29 22:56:34.459: I/dalvikvm(31424): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:601)
12-29 22:56:34.459: I/dalvikvm(31424): at dalvik.system.NativeStart.main(Native Method)
12-29 22:56:34.459: E/dalvikvm(31424): VM aborting
12-29 22:56:34.459: A/libc(31424): Fatal signal 6 (SIGABRT) at 0x00007ac0 (code=-6), thread 31424 (udconference.ly)
Thank you for help.
Android ndk crash: ReferenceTable overflow 11 years 6 months ago #8251
Our developers will check it and get back to you
The following user(s) said Thank You: minionion
Android ndk crash: ReferenceTable overflow 11 years 6 months ago #8252
OK, fixed, forgot to invoke ReleaseFloatArrayElements
Android ndk crash: ReferenceTable overflow 11 years 6 months ago #8259
  • Hewie
Thanks for your help!
Our project used PDF SDK Version(2.3.9).
We need get the same Version(2.3.9) fixed solutions.
Could you help us?
My Email : This email address is being protected from spambots. You need JavaScript enabled to view it.
Android ndk crash: ReferenceTable overflow 11 years 6 months ago #8264
The new version 3.3.4 has a fix for your issue.
Sorry but we cannot apply the fix for the requested version, as it's very old one and the native APIs has been changed significantly since then.
