OutOfMemoryError when use radaee library 11 years 6 months ago #8338
  • asliyanage
I used radaee library for my app.
I have customized the PDFReader class.
package com.sph.pdf;
import android.app.Activity;
import android.content.Context;
import android.content.Intent;
import android.text.InputFilter;
import android.text.InputType;
import android.util.AttributeSet;
import android.util.Log;
import android.util.TypedValue;
import android.view.Gravity;
import android.widget.EditText;
import com.radaee.pdf.Page;
import com.radaee.reader.PDFReader;
import com.radaee.util.ComboList;
import com.radaee.view.PDFView.PDFPos;
import com.sph.controller.SPHApplication;
public class SPHCustomizedRadaeePDFReader extends PDFReader {
	private Context context;
	public SPHCustomizedRadaeePDFReader(Context context, AttributeSet attrs) {
		super(context, attrs);
		this.context=context;
		// TODO Auto-generated constructor stub
	protected void onSizeChanged(int w, int h, int oldw, int oldh) {
		//if(oldw==0||oldh==0){
			super.onSizeChanged(w, h, oldw, oldh);
			Log.d("SAMEERA", " SPHCustomizedonSizeChanged onSizeChanged " +context);
	public boolean OnPDFSingleTapped(float x, float y) {
		//context=SPHApplication.getContext();
		Log.d("ASL", " SPHCustomizedRadaeePDFReader OnPDFSingleTapped " +context);
		String tap="SingleTapped";
		PDFActivity activity = (PDFActivity) context;
		activity.tapDetected();
		Intent intent = new Intent();
		//intent.putExtra("OnPDFSingleTapped",tap);
		intent.setAction("com.tutorialspoint.CUSTOM_INTENT");
		context.sendBroadcast(intent);*/
		return super.OnPDFSingleTapped(x,y);
	// sameera
		public static boolean Swipeable() {
			//return false;
			return status;
		// sameera
		public void isPdfSwipeable() {
			if (m_view != null) {
				/*Log.d("ASL","truetrue m_view.vGetWinH()  "+m_view.vGetWinH());
				Log.d("ASL","truetrue m_view.vGetWinW()  "+m_view.vGetWinW());
				Log.d("ASL","truetrue m_view.vGetX()  "+m_view.vGetX());
				Log.d("ASL","truetrue m_view.vGetY()  "+m_view.vGetY());*/
				if (m_view.vGetScale() == m_view.vGetMinScale()) {
					status = true;
					//if(m_view.vGetX() + m_view.vGetWinW() >= m_view.vGet)
					Log.d("ASL","truetrue m_view.vGetX()  "+m_view.vGetWinW());
				} else {
					status = false;
					/*if(m_view.vGetX()!=0){
						status = false;
					else{
						status = true;
					Log.d("ASL","falsefalse  m_view.vGetX()  "+m_view.vGetX());*/
	public boolean OnPDFDoubleTapped(float x, float y) {
		//Log.d("SAMEERA", "OnPDFDoubleTapped");
		 * if( m_status != STA_NORMAL ) return false;
		 * m_view.vSetScale(m_view.vGetScale() + Global.zoomStep, x, y);
		//Log.d("SAMEERA", "m_view.vGetScale() "+m_view.vGetScale());
		//Log.d("SAMEERA", "OnPDFDoubleTapped IFF");
		if(true){
			m_view.vSetScale(m_view.vGetMaxScale(), x, y);
		//	Log.d("SAMEERA", "OnPDFDoubleTapped IFF "+m_view.vGetScale());
		} else {
			m_view.vSetScale(m_view.vGetMinScale(), x, y);
			//Log.d("SAMEERA", "OnPDFDoubleTapped ELSE  "+m_view.vGetMinScale());
		}else{
				//if(m_view.vGetMaxScale()<9.598424f)
				if(m_view.vGetMaxScale()<9.598424f){
				else{
					m_view.vSetScale(9.598424f, x, y);
			} else {
			//}9.598424
		return true;
when i run the app i got below exception
01-20 16:56:47.309: W/System.err(18508): java.lang.OutOfMemoryError
01-20 16:56:47.314: W/System.err(18508): 	at android.graphics.Bitmap.nativeCreate(Native Method)
01-20 16:56:47.314: W/System.err(18508): 	at android.graphics.Bitmap.createBitmap(Bitmap.java:726)
01-20 16:56:47.314: W/System.err(18508): 	at android.graphics.Bitmap.createBitmap(Bitmap.java:703)
01-20 16:56:47.314: W/System.err(18508): 	at android.graphics.Bitmap.createBitmap(Bitmap.java:670)
01-20 16:56:47.314: W/System.err(18508): 	at com.radaee.view.PDFView.vResize(PDFView.java:218)
01-20 16:56:47.314: W/System.err(18508): 	at com.radaee.view.PDFViewDual.vResize(PDFViewDual.java:62)
01-20 16:56:47.319: W/System.err(18508): 	at com.radaee.reader.PDFReader.onSizeChanged(PDFReader.java:1140)
01-20 16:56:47.319: W/System.err(18508): 	at com.sph.pdf.SPHCustomizedRadaeePDFReader.onSizeChanged(SPHCustomizedRadaeePDFReader.java:34)
01-20 16:56:47.319: W/System.err(18508): 	at android.view.View.sizeChange(View.java:15326)
01-20 16:56:47.319: W/System.err(18508): 	at android.view.View.setFrame(View.java:15290)
01-20 16:56:47.319: W/System.err(18508): 	at android.view.View.layout(View.java:15201)
01-20 16:56:47.319: W/System.err(18508): 	at android.widget.RelativeLayout.onLayout(RelativeLayout.java:1076)
01-20 16:56:47.319: W/System.err(18508): 	at android.view.View.layout(View.java:15204)
01-20 16:56:47.319: W/System.err(18508): 	at android.view.ViewGroup.layout(ViewGroup.java:4793)
01-20 16:56:47.324: W/System.err(18508): 	at android.widget.RelativeLayout.onLayout(RelativeLayout.java:1076)
01-20 16:56:47.324: W/System.err(18508): 	at android.view.View.layout(View.java:15204)
01-20 16:56:47.324: W/System.err(18508): 	at android.view.ViewGroup.layout(ViewGroup.java:4793)
01-20 16:56:47.324: W/System.err(18508): 	at android.widget.FrameLayout.onLayout(FrameLayout.java:448)
01-20 16:56:47.324: W/System.err(18508): 	at android.support.v4.view.ViewPager.onLayout(ViewPager.java:1594)
01-20 16:56:47.329: W/System.err(18508): 	at android.view.ViewGroup.layout(ViewGroup.java:4793)
01-20 16:56:47.329: W/System.err(18508): 	at android.widget.RelativeLayout.onLayout(RelativeLayout.java:1076)
01-20 16:56:47.329: W/System.err(18508): 	at android.view.View.layout(View.java:15204)
01-20 16:56:47.329: W/System.err(18508): 	at android.widget.FrameLayout.onLayout(FrameLayout.java:448)
01-20 16:56:47.329: W/System.err(18508): 	at android.widget.LinearLayout.setChildFrame(LinearLayout.java:1677)
01-20 16:56:47.334: W/System.err(18508): 	at android.widget.LinearLayout.layoutVertical(LinearLayout.java:1531)
01-20 16:56:47.334: W/System.err(18508): 	at android.widget.LinearLayout.onLayout(LinearLayout.java:1440)
01-20 16:56:47.334: W/System.err(18508): 	at android.view.View.layout(View.java:15204)
01-20 16:56:47.334: W/System.err(18508): 	at android.view.ViewGroup.layout(ViewGroup.java:4793)
01-20 16:56:47.334: W/System.err(18508): 	at android.widget.FrameLayout.onLayout(FrameLayout.java:448)
01-20 16:56:47.339: W/System.err(18508): 	at android.view.ViewRootImpl.performLayout(ViewRootImpl.java:2260)
01-20 16:56:47.339: W/System.err(18508): 	at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:2007)
01-20 16:56:47.339: W/System.err(18508): 	at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1249)
01-20 16:56:47.339: W/System.err(18508): 	at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:6364)
01-20 16:56:47.339: W/System.err(18508): 	at android.view.Choreographer$CallbackRecord.run(Choreographer.java:791)
01-20 16:56:47.339: W/System.err(18508): 	at android.view.Choreographer.doCallbacks(Choreographer.java:591)
01-20 16:56:47.339: W/System.err(18508): 	at android.view.Choreographer.doFrame(Choreographer.java:561)
01-20 16:56:47.344: W/System.err(18508): 	at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:777)
01-20 16:56:47.344: W/System.err(18508): 	at android.os.Handler.handleCallback(Handler.java:730)
01-20 16:56:47.344: W/System.err(18508): 	at android.os.Handler.dispatchMessage(Handler.java:92)
01-20 16:56:47.344: W/System.err(18508): 	at android.os.Looper.loop(Looper.java:176)
01-20 16:56:47.344: W/System.err(18508): 	at android.app.ActivityThread.main(ActivityThread.java:5419)
01-20 16:56:47.349: W/System.err(18508): 	at java.lang.reflect.Method.invokeNative(Native Method)
01-20 16:56:47.349: W/System.err(18508): 	at java.lang.reflect.Method.invoke(Method.java:525)
01-20 16:56:47.349: W/System.err(18508): 	at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1046)
01-20 16:56:47.349: W/System.err(18508): 	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:862)
01-20 16:56:47.349: W/System.err(18508): 	at dalvik.system.NativeStart.main(Native Method)
01-20 16:56:47.359: W/FlurryAgent(18508): Error logged: uncaught
01-20 16:56:47.499: W/FlurryAgent(18508): Flurry session finalized
01-20 16:56:49.769: W/com.newrelic.agent.android(18508): setBytesReceived(...) called on TransactionState in COMPLETE state
01-20 16:56:49.769: W/com.newrelic.agent.android(18508): setStatusCode(...) called on TransactionState in COMPLETE state
01-20 16:56:49.769: W/FlurryAgent(18508): Analytics report sent.
01-20 16:56:53.744: I/com.newrelic.agent.android(18508): Crash 825aa35e-5797-13f5-e516-450a3bf545d4 successfully submitted.
01-20 16:56:55.494: D/dalvikvm(18508): GC_FOR_ALLOC freed 5586K, 14% free 56169K/64984K, paused 56ms, total 56ms
01-20 16:56:55.664: E/AndroidRuntime(18508): FATAL EXCEPTION: main
01-20 16:56:55.664: E/AndroidRuntime(18508): java.lang.OutOfMemoryError
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.graphics.Bitmap.nativeCreate(Native Method)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.graphics.Bitmap.createBitmap(Bitmap.java:726)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.graphics.Bitmap.createBitmap(Bitmap.java:703)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.graphics.Bitmap.createBitmap(Bitmap.java:670)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at com.radaee.view.PDFView.vResize(PDFView.java:218)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at com.radaee.view.PDFViewDual.vResize(PDFViewDual.java:62)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at com.radaee.reader.PDFReader.onSizeChanged(PDFReader.java:1140)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at com.sph.pdf.SPHCustomizedRadaeePDFReader.onSizeChanged(SPHCustomizedRadaeePDFReader.java:34)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.view.View.sizeChange(View.java:15326)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.view.View.setFrame(View.java:15290)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.view.View.layout(View.java:15201)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.widget.RelativeLayout.onLayout(RelativeLayout.java:1076)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.view.View.layout(View.java:15204)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.view.ViewGroup.layout(ViewGroup.java:4793)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.widget.FrameLayout.onLayout(FrameLayout.java:448)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.support.v4.view.ViewPager.onLayout(ViewPager.java:1594)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.widget.LinearLayout.setChildFrame(LinearLayout.java:1677)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.widget.LinearLayout.layoutVertical(LinearLayout.java:1531)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.widget.LinearLayout.onLayout(LinearLayout.java:1440)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.view.ViewRootImpl.performLayout(ViewRootImpl.java:2260)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:2007)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1249)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:6364)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.view.Choreographer$CallbackRecord.run(Choreographer.java:791)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.view.Choreographer.doCallbacks(Choreographer.java:591)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.view.Choreographer.doFrame(Choreographer.java:561)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:777)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.os.Handler.handleCallback(Handler.java:730)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.os.Handler.dispatchMessage(Handler.java:92)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.os.Looper.loop(Looper.java:176)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at android.app.ActivityThread.main(ActivityThread.java:5419)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at java.lang.reflect.Method.invokeNative(Native Method)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at java.lang.reflect.Method.invoke(Method.java:525)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1046)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:862)
01-20 16:56:55.664: E/AndroidRuntime(18508): 	at dalvik.system.NativeStart.main(Native Method)
OutOfMemoryError when use radaee library 11 years 6 months ago #8340
it is better of you to use PDFLayoutView, if zoom level greater that 4.
PDFReader cost more memory, in large zoom level, because it render whole page as 1 bitmap.
OutOfMemoryError when use radaee library 11 years 6 months ago #8342
  • asliyanage
could you pls provide me how to open pdf file using PDFLayoutView?
I know we can open pdf using PDFReader as below.
m_reader.PDFOpen(m_doc, false, this);
m_reader.PDFSetView(3);
OutOfMemoryError when use radaee library 11 years 6 months ago #8343
  • asliyanage
OutOfMemoryError when use radaee library 11 years 6 months ago #8344
yes, mostly methods are same.
plz see PDFLayoutAct, and you can launch PDFLayoutAct, modify start Activity in AndroidManifest.xml
OutOfMemoryError when use radaee library 11 years 6 months ago #8345
  • asliyanage
i remember you told once PDFLayoutAct is still in beta version.Is it good to use this class in production.we are doing commercial item.
