How to add a single point to PDF page content 11 years 5 months ago #8455
  • ashughes
  • ashughes's Avatar Topic Author
I need to draw only a single point in the content of a PDF page. I tried to draw a line from and to the same x,y point, but no point appears in the PDF. For example:
content.GSSave();
content.SetStrokeColor(color);
content.SetStrokeJoin(1); // round
content.SetStrokeCap(1); // round
content.SetStrokeWidth(width);
Path path = new Path();
path.MoveTo(x1, y1);
path.LineTo(x1, y1);
content.StrokePath(path);
path.Destroy();
content.GSRestore();
pdfPage.AddContent(content, false);
content.Destroy();
However, when I tried just adding a small amount to the point passed into LineTo(), it did work:
content.GSSave();
path.LineTo(x1+0.001f, y1+0.001f); // <- Added 0.001f to the point
path.Destroy();
content.Destroy();
Is this what I need to do? Or is there a more correct way to draw a single point to the content of a PDF page? Or is this a bug in the SDK?
Andrew
How to add a single point to PDF page content 11 years 5 months ago #8525
it is checked in native library, if moveto is same to lineto point, shall ignored lineto point.
to draw single point: add a small rectangle to page is better.
How to add a single point to PDF page content 11 years 5 months ago #8546
  • ashughes
Thanks for the clarification. I don't see any methods in PageContent or Path to draw a rectangle. Could you clarify what you mean?
Are there any issues with the way I mentioned in my original post (adding a second point to a line that is very slightly different than the first point)?
Andrew
How to add a single point to PDF page content 11 years 5 months ago #8577
  • ashughes
This is what I ended up doing to work around the issue:
private void drawPoint(PageContent content, float x, float y, float width) {
    path.MoveTo(x, y);
    path.LineTo(Float.intBitsToFloat(Float.floatToIntBits(x) + 1), Float.intBitsToFloat(Float.floatToIntBits(y) + 1)); // This adds one bit to the floats x and y, causing them to be the smallest possible difference from x and y
    path.Destroy();
It seems like a better solution would be to add a
PageContent.DrawPoint(float x, float y, float width)
PageContent.StrokePoint(float x, float y)
that uses the width from
PageContent.SetStrokeWidth(width)
or even adding something to Path that adds a point.
Andrew
How to add a single point to PDF page content 11 years 4 months ago #8597
path.LineTo(x1, y1 + 1);
path.LineTo(x1 + 1, y1 + 1);
path.LineTo(x1 + 1, y1);
path.ClosePath();
content.FillPath(path);
path.Destroy();
//todo: add content to page.
