How do you delete an outline in Android? 11 years 5 months ago #8586
  • gtoldosProton
  • gtoldosProton's Avatar Topic Author
I have this code inside a method.... outline.RemoveFromDoc(); works in the beggining but after several times it gives me a
02-26 17:14:43.098: A/libc(5454): Fatal signal 11 (SIGSEGV) at 0x00000010 (code=1), thread 5454 (com.xxxxxx)
This is kind of the same problems I have found with iOS.... and that hopefully will be fixed in the version you just released.
public void onRemove(int outlineIndex) {
Outline outline = mBookmarkFragment.getOutline(outlineIndex);
if (outline != null) {
refreshOutLines();
thanks for your attention and good support
How do you delete an outline in Android? 11 years 4 months ago #8594
seems no method mBookmarkFragment.getOutline(outlineIndex);
if u stored outlines in an array:
remove Outline object element at array.
and then modified all index value for all outlines in array.
example: 10 outlines, u removed index at 5, outline 6 to be 5, 7 to be 6 and so on.
How do you delete an outline in Android? 11 years 4 months ago #8595
others: remove parent Outline, shall cause all children not aviable.
