"Fatal Signal 11" after Document.GetPage(int) 11 years 5 months ago #8590
  • alexander.gustke
  • alexander.gustke's Avatar Topic Author
Hello everybody,
i've got the problem, that when i call
Document.GetPage(pageno)
(pageno >= 0 && pageno < Document.GetPageCount()) my app crashes with this message:
A/libc﹕ Fatal signal 11 (SIGSEGV) at 0x0000001c (code=1), thread 6396
The error is not reproducible for a single pdf - it happens from time to time.
There are another topics related to the same error message, but non of them happened by a call to GetPage().
Does anybody have suggestions?
Thanks, Alex
Last edit: by alexander.gustke.
"Fatal Signal 11" after Document.GetPage(int) 11 years 5 months ago #8591
Dear Alexander, may you include some more details about your code?
Information you're giving are really poor and we can't do good evaluation on that.
Some questions:
Are you experiencing the issue within the demo project too?
Are you experiencing the issue with your own pdf file? May you provide us some?
"Fatal Signal 11" after Document.GetPage(int) 11 years 5 months ago #8592
  • gtoldosProton
  • gtoldosProton's Avatar
I also get those in several places. Both in iOS and Android. It comes from a segmentation faults, as long as I know (or think to know). It also happens from time to time, and not always under the same context. And it rises from different places of the lib. Not with GetPage... though... yet.
"Fatal Signal 11" after Document.GetPage(int) 11 years 5 months ago #8593
There are only two reasons I could think about:
- some uncommon datas in your PDF file: I invite you to open a trouble ticket about bug and send us a sample file
- some wrong code in your source: let's us get some more example about your own code
Are you experiencing the same within the demo app?
If so I suggest you to start from the first step.
The only doubt is about the randomic way crashes are happening.
Last edit: by support.
"Fatal Signal 11" after Document.GetPage(int) 11 years 4 months ago #8601
  • alexander.gustke
I figured out the source of the crash: i opened the same page in a Document instance twice (in different theads).
Solution: Don't open the same page twice... - resolves the crashes in my app.
The following user(s) said Thank You: support
"Fatal Signal 11" after Document.GetPage(int) 11 years 4 months ago #8602
Thank you for your feedback.
