Curl and controls 11 years 3 months ago #8829
  • Truerall
  • Truerall's Avatar Topic Author
Hi
I need to implement pdf reader in my app. I deciced to do it using this lib.
What I have found surfing demo project:
- I can implement nice and fast viewer with controls using PDFLayoutView and PDFViewController classes.
- I can impement Curl effect on page change using CurlView class.
But I cant connect privous two cases. PDFViewController cant be attached to CurlView.
Also I tried
m_view.PDFSetView(2); // m_view is instance of PDFLayoutView
because I have found next topic
www.radaeepdf.com/forum/Android-developm...er-pdfsetview-x#8319
during forum search.
and here is my question :
Is there way to implement curl page change with controls using this library ?
Curl and controls 11 years 3 months ago #8832
As the layout PDFLayoutView is not yet defenitive, and the Curl view class is based on OpenGl interfaces the zoom feature is not yet supported.
File Attachment:
File Name: PDFViewCurl.java
File Size:12 KB
Here you can find an example of a class that is based on PDFViewDual, that supports curl effect (in case zoom factor = 1), and uses the curl effect from the native library. (note: some variables in PDFView needs to be protected and to modify these classes you need at least the professional license)
Curl and controls 11 years 2 months ago #8902
  • Truerall
Thank you very much for your help!
