scale pdf page in height not in width
11 years 3 months ago
#8851
alberto.penas
New Member
Hi, i am watching in your library for some option to change the visualization scale of the pdf to fit the screen in height not in width. ¿Is there a way to do this?.
thanks
#8854
Davide
User is blocked
Thank you received: 65
try to change def_view parameter in default_config() method of Global class.
To fit the screen in height you should use:
def_view = 1;
def_view = 3;
This will help you:
www.radaeepdf.com/forum/Android-developm...n-scale?start=6#7240
Last edit: by
Davide
Get page gap value in PDFLayoutDual
