Saving Annotation (ink) on permanently on PDF 10 years 10 months ago #9005
  • scott2srikanth
  • scott2srikanth's Avatar Topic Author
Can I save signature (ink annotation) on PDF permanently?
I used
m_doc.Save();
and able to save the annotations, but these the annotation are editable when ever I open the PDF.
Can we stop preventing editing saved annotation generally(ink annotations)?
Saving Annotation (ink) on permanently on PDF 10 years 10 months ago #9006
yes you should use
m_annot.SetLocked(true);
This method has been fixed in the last beta version : was corrupting text fields rendering.
You can safely use the beta, we are expecting to promote to stable version friday next week.
The following user(s) said Thank You: scott2srikanth
Saving Annotation (ink) on permanently on PDF 8 years 3 months ago #13183
  • rohitgarg2990
  • rohitgarg2990's Avatar
It would be great help if you can tell where exactly to call this method.
Saving Annotation (ink) on permanently on PDF 8 years 3 months ago #13184
it dipends on your needs.
For example you can lock annot after adding it with something like this :
Annotation annot = page.GetAnnot(page.GetAnnotCount() - 1);     //get last added annot
Saving Annotation (ink) on permanently on PDF 8 years 3 months ago #13211
  • rohitgarg2990
Hi, i tried your solution before saving the pdf, but it did not work. My exact requirement is that i want to make the annotation just like text so that if someone opens it in pdf reader and they won't be able to delete that annotation. Right now, if i save it and open it on laptop, i can remove the annotation but text i can not remove.
Saving Annotation (ink) on permanently on PDF 8 years 3 months ago #13215
You can call Page.FlatAnnots -> this will make the annotations part of the page content and cannot be removed.
but it will flatten all the annotations contained in this page
This method requires the premium license.
