Saving Annotation (ink) on permanently on PDF 8 years 7 months ago #13225
  • rohitgarg2990
  • rohitgarg2990's Avatar
Hi Nermeen,
thanks for your reply. I tested that and it is working for windows but not for Mac. Can you please verify the same?
Regards,
Rohit Garg
Saving Annotation (ink) on permanently on PDF 8 years 7 months ago #13226
Dear Rohit,
By Mac you mean the iOS version?
The method for annot flatting is returning false?
Saving Annotation (ink) on permanently on PDF 8 years 7 months ago #13231
  • rohitgarg2990
Hi Nermeen,
I mean when i open the saved pdf with annotation on windows laptop, i can not delete the annotation with pdf reader but when i open the same pdf on mac machine, i can remove it. Isn't it suppose to flat annotations for all the platforms?
Regards,
Rohit Garg
Saving Annotation (ink) on permanently on PDF 8 years 7 months ago #13232
can you please send us the pdfs you used (before and after the flat)?
Can you please show us the code you use to flatten and save the pdf?
Thanks!
Saving Annotation (ink) on permanently on PDF 8 years 7 months ago #13238
  • rohitgarg2990
Hi Code is as follows, i will try to share the pdf as soon as possible.
Paint paint = m_ink.getM_paint();
paint.setStrokeWidth(width);
m_ink.setM_paint(paint);
m_status = STA_NONE;
if( m_annot_page != null )
Page page = m_doc.GetPage(m_annot_page.GetPageNo());
if( page != null )
// Annotation annot = page.GetAnnot(page.GetAnnotCount() - 1); //get last added annot
// annot.SetLocked(true);
page.ObjsStart();
Matrix mat = m_annot_page.CreateInvertMatrix(m_layout.vGetX(), m_layout.vGetY());
mat.TransformInk(m_ink);
page.AddAnnotInk(m_ink);
page.FlatAnnots();
mat.Destroy();
//add to redo/undo stack.
m_opstack.push(new OPAdd(m_annot_page.GetPageNo(), page, page.GetAnnotCount() - 1));
m_layout.vRenderSync(m_annot_page);
page.Close();
if( m_listener != null )
m_listener.OnPDFPageModified(m_annot_page.GetPageNo());
if( m_ink != null ) m_ink.Destroy();
m_ink = null;
m_annot_page = null;
invalidate();
Saving Annotation (ink) on permanently on PDF 8 years 7 months ago #13239
  • rohitgarg2990
my license is professional, for me, setLock is working for me for windows but not for iOS.. Do you get the idea or should i still share the pdf?
