Issue with the method RenderIsFinished() 11 years 1 month ago #9045
  • arcmobile.div
  • arcmobile.div's Avatar Topic Author
There is a method RenderIsFinished() in Page.java , package com.radaee.pdf
After document is rendered on the viewer , RenderIsFinished returns value true only once.
Next time onwards , whenever a call to the method RenderIsFinished() is done , the value is returned as false.
Kindly update.
Issue with the method RenderIsFinished() 11 years 1 month ago #9048
can you please better explain your issue?
I've checked this method, as example in PDFPerformAnnot() method (called when you click an annotation and press the "do" button), using:
m_annot_page.GetPage().RenderIsFinished();
and in the OnPDFSingleTapped method with:
page.RenderIsFinished();
and they seem to work properly and return true everytime.
Issue with the method RenderIsFinished() 11 years 1 month ago #9098
  • arcmobile.div
After a document is rendered on the device screen , the RenderIsFinished() is returning true.
Now , let us assume that the user draws annotations like Line , Rectangle on the document and rendering is complete.
Now , I need to generate the bitmap of the document with annotations and not the entire screen. Here , I am facing issue generating the bitmap .
So , I checked the method RenderIsFinished() and its returning false.
What can the possible cause of the issue ?
Issue with the method RenderIsFinished() 11 years 1 month ago #9139
can you please send us your code?
So we can check it and try to help you..
Issue with the method RenderIsFinished() 11 years 1 month ago #9142
  • arcmobile.div
The document is rendered completely on the device , Now , the call to the RenderIsFinised is returning true.
Now , I am trying to generate the thumbnail of that specific page of the document on a button click using the following code:
public Bitmap generateThumbNails(Document mdoc, int pageNo, int quality) {
Page page = mdoc.GetPage(pageNo);
Bitmap bmp = null;
try {
float w = mdoc.GetPageWidth(pageNo);
float h = mdoc.GetPageHeight(pageNo);
bmp = Bitmap.createBitmap(quality, (int) (h / (w / quality)), Bitmap.Config.ARGB_8888);
int ih = (int) (h / (w / quality));
bmp.eraseColor(0);
float ratiox = quality / w;
float ratioy = ih / h;
if (ratiox > ratioy)
ratiox = ratioy;
if (!page.RenderThumb(bmp)) {
Canvas canvas = new Canvas(bmp);
Paint paint = new Paint();
paint.setARGB(255, 255, 255, 255);
canvas.drawRect((quality - w * ratiox) / 2, (ih - h * ratiox) / 2, (quality + w * ratiox) / 2, (ih + h
* ratiox) / 2, paint);
Matrix mat = new Matrix(ratiox, -ratiox, (quality - w * ratiox) / 2, (ih + h * ratiox) / 2);
page.RenderToBmp(bmp, mat);
mat.Destroy();
if (!page.RenderIsFinished()) {
bmp.recycle();
bmp = null;
page.Close();
} catch (Exception e) {
return bmp;
In the above code , RenderIsFinised is returning as false and an empty thumbnail is getting generated.
Kindly provide your inputs.
Last edit: by arcmobile.div.
Issue with the method RenderIsFinished() 11 years 3 weeks ago #9191
Now the request is clear.
I should check in our framework code.
I'll update you as soon as possible.
