Resize problem on PDFViewDual 11 years 1 month ago #9050
  • barwoź
  • barwoź's Avatar Topic Author
Hello
i have a problem with PDFViewDual, actually i can't resize my pdf file. After pinch screen aplication quiclky moves to center of page and then resize.
there is a problem with page slider too - page not refresh after slide and doesn't move to that page before touch screen.
Please help me, i haven't got any idea how to solve it.
code:
import android.content.Context;
import android.util.Log;
import android.view.MotionEvent;
import com.radaee.pdf.Document;
import com.radaee.reader.PDFLayoutView;
import com.radaee.view.PDFView;
import com.radaee.view.PDFView.PDFPos;
import com.radaee.view.PDFView.PDFViewListener;
import com.radaee.view.PDFViewCurl;
import com.radaee.view.PDFViewDual;
import com.radaee.view.PDFViewHorz;
import com.radaee.view.PDFViewVert;
public class PDFDoc extends PDFViewDual{
	private static final String TAG = "PDFDoc";
	public PDFDoc(Context context) {
		super(context);
	public Document viewGetDoc() {
		return m_doc;
public boolean vMovingFinished() {
	Log.i(TAG,"vMovingFinished");
	return super.vMovingFinished();
public boolean vTouchEvent(MotionEvent event) {
	return super.vTouchEvent(event);
	public void setViewListener(PDFViewListener listener) {
		m_listener=listener;
	public int ilestron() {
		return m_doc.GetPageCount();
	public PDFPos getPosition() {
		PDFPos pos=vGetPos(0,0);
		if(pos!=null)
			Log.i(TAG, "getPostion"+m_h+" "+m_w+" "+vGetX()+" "+vGetY());
		pos.x=-vGetX();
		pos.y=-vGetY();
		if(pos.y<0)
			pos.y=0;
		pos.pageno=vGetPage((int)-pos.x, (int)-pos.y);
		return pos;
	public PDFPos getRealPostion() {
		return pos;
	public int getWidthLayer()
		int szerokosc = (int)m_doc.GetPageWidth(0);
		return szerokosc;
	 public void vScrollPDF(int newX, int newY){
			Log.i(TAG,"vScrollPDF"+newX+" "+newY);
			if(m_scroller != null){
				m_scroller.setFinalX(newX);
				m_scroller.setFinalY(newY);
				m_scroller.computeScrollOffset();
	 public int get_scrollerX()
		 return m_scroller.getCurrX();
	 public int get_scrollerY()
		 return m_scroller.getCurrY();
	/*public  PDFPos vSetPos(PDFPos pos, float x, float y) {
		// TODO Auto-generated method stub
		pos.x = x;
		pos.y = y;
		return pos;
Resize problem on PDFViewDual 11 years 1 month ago #9063
I have take a look at your code, can you give us more info about your problem?
What is your target? What do you wanna create with this code?
