Horizontal View in PDFViewLayout 11 years 1 month ago #9069
  • dashti
  • dashti's Avatar Topic Author
I want to update my application with SDK 3.4 and use PDFViewLayout. I need to use horizontal view which was present in old PDFReader but now there is no such option in PDFViewLayout. Is it possible to edit codes in the library to access this option?
BTW, PDFReader.PDFOpen has rtol while in PDFViewLayout.PDFOpen it is not present.
Horizontal View in PDFViewLayout 11 years 1 month ago #9079
can you please better explain your needs?
What do you mean for horizontal view? Try to set def_view = 1 parameter of default_config() method
BTW, If you have a Professional or a Premium license you can follow this to get the library source code and edit what you want.
Horizontal View in PDFViewLayout 11 years 1 month ago #9084
  • dashti
In PDFLayoutView.PDFSetView() there is a switch on Global.def_view which does not have any case 1 (horizontal view) and its default goes to PDFLayoutVert.
I do have full license, but there is nothing like PDFLayoutHoriz in the library to use that. Which class I should edit to have something like PDFLayoutHoriz?
Horizontal View in PDFViewLayout 11 years 1 month ago #9091
you can try to edit PDFSetView() method of PDFLayoutView class and handle case 1 (horizontal view) as you want.
